Old Oct 1st, 2003, 03:33 AM   #1 (permalink)
chucky200
fixing rattling flex pipe connection
After what I thought was the heat shield, ends up being my flex pipe rattling.
Basically at 2,000 rpm, it rattles REALLY loud and it's only getting worse. Upon closer inspection while banging my exhaust pipe (b4 the CAT) with a hammer, I found the problem was at the section where the exhaust pipe (around the oil pan area) meets with the flex pipe (about halfway to the CAT). So where one pipe goes into the other... this connection is loose.
So my question is how to tighen/stabilize these pipes to stop them from rattling against each other. Does a small section have to be welded?
chucky200 is offline   Reply With Quote
Old Oct 1st, 2003, 07:22 AM   #2 (permalink)
niky
Doodeee doodee doodee doo
niky's Avatar
yup.
my flex pipe is a bitch also, it buzzes like mad.
Bigbigcar.com
My new hobby... driving.
Ford Lynx RS / Mazda Protege MP3: Slow but Furious out of the box. :D
niky is offline   Reply With Quote
Old Oct 1st, 2003, 09:08 AM   #3 (permalink)
holy200sx
Banned
Send a message via AIM to holy200sx Send a message via Yahoo to holy200sx
yea.. you will have to weld it back together..
holy200sx is offline   Reply With Quote
Old Oct 1st, 2003, 11:37 PM   #4 (permalink)
HoloSkull
Faster! FASTER!!!
HoloSkull's Avatar
Send a message via AIM to HoloSkull
I didn't have to weld mine and it isn't rattling...
(or have I just gotten used to it?)
Cherry Bombs make great dual exhaust... Removing them make people cry.
Ram Air made with Hood scoop a work in progress.
If I was really interested in what kind of car you had, I'd look in my rear view mirror...
Check out My Sentra and my racing team
HoloSkull is offline   Reply With Quote
Old Oct 2nd, 2003, 10:27 AM   #5 (permalink)
holy200sx
Banned
well see the thing is. you probably have a small crack in the exhaust pipe.. well after the pipe gets the crack,e xhaust is constantly leaking out of that crack, at 2000rpms it just so happens to make it rattle.. well.. while exhasut is hitting it, heat makes matter spread/stretch, so its stretching that crack, and when you turn your car off it shrinks back down.. this is whats causing it to get worse and worse...
