Old Aug 27th, 2003, 06:52 PM   #1 (permalink)
NotAnotherHonda
Have I Hit 12's Yet?
NotAnotherHonda's Avatar
power lock problems
ok...the other day i left my windows down in the rain, and ever sice, my poweer locks havent been working right...i cant unlock them sometimes, and sometimes they just start having spasms and going from lock to unlock for like 2 minutes...i checked my fuses...i think...you guys have any ideas?!?!?!i have a 95 20sx se...
95 200sx se. sr20de, gt28r, bb manifold, forge fmic, greddy bov and bc, tial 38mm, walbro 255, apexi tt, 3" exhaust with magnaflow, 3" downpipe, jgy clutch flywheel and fuel rail, msd 50#'s, cobra maf, jwt ecu and s4's, nismo fpr, autometer, nissport adaptors, fal pushers, ur pulley, m/t 22x8x15 et drags.
NotAnotherHonda is offline   Reply With Quote
Old Aug 27th, 2003, 08:08 PM   #2 (permalink)
Cullam3n
Send a message via ICQ to Cullam3n Send a message via AIM to Cullam3n Send a message via Yahoo to Cullam3n
When you say you unlock them... are you using the power locks that are on the doors that got soaked? If so, does it do the samr thing on both doors?
Or are you using the remote key lock?
-PC
Cullam3n is offline   Reply With Quote
Old Aug 27th, 2003, 08:45 PM   #3 (permalink)
azkicker0027
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
the obvious cause would be the wet master switch, those things are a tad sensitive to liquids.....
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://www.200sxonline.com/community/
azkicker0027 is offline   Reply With Quote
Old Aug 27th, 2003, 09:14 PM   #4 (permalink)
BillDawg
I'd just go on eBay Motors under the Parts -> Car & Truck section and get yourself a cheap set of new/used switches. eBay is usually great for stuff like that.
BillDawg is offline   Reply With Quote
Old Aug 27th, 2003, 11:53 PM   #5 (permalink)
Beltane70
Send a message via ICQ to Beltane70
I get a similar problem after a heavy rainfall. It usually only lasts a day or so.
Beltane70 is offline   Reply With Quote
Old Aug 28th, 2003, 12:49 AM   #6 (permalink)
Mazoku
Send a message via AIM to Mazoku
Mine do the exact same thing. Either when they get wet or when its really cold outside. Someone once suggested that the contacts get corroded and should be cleaned. I haven't done anything about it yet myself. Like Beltane said, it should stop in a little while.
Mazoku is offline   Reply With Quote
Old Aug 28th, 2003, 12:20 PM   #7 (permalink)
NotAnotherHonda
yea they only dont work when i use the power lock switch, not wehen i manually unlock them myself...and i havent tried the passenger side switches yet...only driver...yea i might try to clean the switches underneath...any more suggestions?
Old Aug 28th, 2003, 12:57 PM   #8 (permalink)
himilefrontier
265k miles and counting..
himilefrontier's Avatar
Send a message via AIM to himilefrontier
I posted about this a month ago.Just let it dry out for a few days and the bad power lock demons wil be exorcized.
1998 Nissan Frontier XE/2wd/5spd 1 owner, 264k miles
1985 Olds Cutlass, 350 Chevy, owned for 14 years
WANTED: 1968-1973 Datsun 510 or 1991-1994 Sentra SE-R
http://www.myspace.com/junkyardengineer
himilefrontier is offline   Reply With Quote
Old Aug 28th, 2003, 09:40 PM   #9 (permalink)
-NiCK-
Send a message via AIM to -NiCK-
I have had the same stoopid problem. My dumarse will leave the windows open and it will rain in, and my locks won't work ( power locks)
i have a passive alarm, even when I engage the alarm ( unlock ) it will LOCK the doors, and when I engage it again ( lock ) it will unlock, lol, pretty funny if u ask me, but yeah let it dry out and it should work, if not replace the switch, c ya
NiCK DuBe
e-MaiL : iLLNiCKLLL@AoL.CoM
LoC : BPT, CT
CaR : 95 SeNTRa & 90 aCCoRD
-NiCK- is offline   Reply With Quote
Old Aug 28th, 2003, 11:36 PM   #10 (permalink)
landlord
pay your rent!
landlord's Avatar
i do this (get the switches wet) about four times a year. when it happens i can drive down the street and my doors will lock and un-lock. one time it got so wet that my windows would roll up and down on there own, really annoying when your driving down the road and its raining like hell and you cant roll the window up! just give it a few days, mine once took three months before they started working right, so it may take longer. it also sucks when you have three thousand in your sterio system and you come out in the morning and your doors are un-locked!
95 200sx timing advanced to 15*, custom cai, Stromung exaust (no cat), b&m short throw shifter, rusted out fenders, worn suspension, creaking balljoints, cracked windshield and bad cv axles. your regular hooptie that requires 92 octane.
landlord is offline   Reply With Quote
Old Aug 30th, 2003, 06:51 PM   #11 (permalink)
himilefrontier
I just fixed my A/C, so I no longer need to drive with the windows down in the rain.It wasn't cheap-$300 for parts(Compressor, Condensor, Dryer, Oil, Refrigerant, O rings and hose for freon)but it was worth it!
Old Aug 30th, 2003, 08:49 PM   #12 (permalink)
Stiletto
Stiletto's Avatar
Basicly the problem is the contacts in the switch mechanisms have very close tolerances. When moisture gets in there it shorts them very easily. Because it is somewhat sealed, it is difficult for the moisture to evaporate. Ive had a few problems with mine and what i do is, remove the one screw that holds the assembly in and take the whole thing out. Let it dry out in the sun then spray the whole thing with some electrical contact cleaner. Keeps them workin good.
Updated! Bigger better pics. Check out my ride:
http://www.cardomain.com/memberpage/408157
Stiletto is offline   Reply With Quote
Old Nov 27th, 2004, 09:56 AM   #13 (permalink)
xxg00chxx
Stupid car. Same issue here, except mine doesn't only happen when it's wet. In fact, it happens all the time. I live in the desert so I assume that after months without rain the system SHOULD be dry.
I have had it with the electrical bullshit in my 93 G20. And now that I read so many other Nissan/Infiniti owners having same stupid issue with door locks, I'm even more disgusted. I thought I just had an isolated issue - apparently the 'issue' is the fact that it's a Nissan.
Maybe if I leave it unlocked someone will just steal it. Knowing this car though, it will probably lock itself anyway. Or, lock and unlock over and over until the battery is dead. Wait, I know, I'll just LOCK it! Then it will surely UNLOCK itself!~!
THOROUGHLY disgusted. Gonna have to trade this heap in before I do something illegal to it.
xxg00chxx is offline   Reply With Quote
Old Dec 2nd, 2004, 10:11 AM   #14 (permalink)
B14_Stealth
new motor & tranny
B14_Stealth's Avatar
Send a message via AIM to B14_Stealth
just replace the controls, u can get them from a junk yard or ebay ..i saw them on ebay like a day ago or so.
B14_Stealth is offline   Reply With Quote
Old Dec 4th, 2004, 07:18 PM   #15 (permalink)
UofLsentra
"It's a good thing"
UofLsentra's Avatar
Send a message via AIM to UofLsentra
My passenger side power locks are messed up, does anyone know if this is the same thing:
My passenger door power lock works fine about 4/10 times. The other 6 times you need to nudge it forward just a little tiny bit (not all the way) then pull it back... or vice versa. How do I resolve this?
Other than getting into the car when it rains every now and then, they don't get wet.
If applicable please refer me to another thread.
'96 Sentra GXE
UofLsentra is offline   Reply With Quote
