Old Jun 10th, 2003, 03:12 AM   #1 (permalink)
LaRon
Send a message via ICQ to LaRon Send a message via AIM to LaRon
Advanced my timing... questions and problems.. expert help plz
Tonight I went ahead and advanced the timing on my 98 200sx SE. I found the instructions in a how-to write up off one of the sites I found on this forum. Well, I had problems with my timing light and couldn't get it working right, so my friend told me we'd do it the way he's always done it, and just advance the timing as far as the dis will turn and then slowly adjust back until the pinging and stuff stops. Well, he slammed it all the way back to the fenderwall, and I hopped in and drove it. It drove and performed GREAT and I could tell a serious difference in my low-end acceleration. The car even runs smoother now. So I've left it fully advanced but I don't know what it's set at because my timing light isn't working right. So what's the most that it is possible to advance my GA16??? Cause that's what it's at. I'm running 93 octane and it's running fine.... I don't hear any pinging or anything. So I'm looking to find out what it's set at if anyone knows beings it's fully advanced.... and what kind of problems could I have from it being this far advanced? Do I need to worry about trying to get another timing light or something?
http://www.cardomain.com/id/xpress200sx
98 200sx SE 5spd, custom short ram intake,
$tillen nose, shortened shifter, Rockford MP3 head unit,
2 10" rockford subs, 300wt rockford amp
LaRon is offline   Reply With Quote
Old Jun 10th, 2003, 08:05 AM   #2 (permalink)
rkeith
My car doesn't like you
rkeith's Avatar
Hey LaRon, where did you get those instructions? Can you give the link plz?.....
Yeah, its got some mods...
rkeith is offline   Reply With Quote
Old Jun 10th, 2003, 11:18 AM   #3 (permalink)
Token Moron
My ass, your face
Token Moron's Avatar
Send a message via AIM to Token Moron Send a message via MSN to Token Moron
the most u should advance a ga16 is 15*, i'd go ask around see who has a timing gun and check at what its at right now, just to be on the safe side
91 se-r : sr20det= the beast
96 sentra : ga16de= pimpness
00 frontier : ka24de= tow truck
01 sentra : gq18de= stock mofo
Token Moron is offline   Reply With Quote
Old Jun 10th, 2003, 11:20 AM   #4 (permalink)
98 nizmo200sx se
98 nizmo200sx se's Avatar
what would happen IF someone had their timming all the way advanced and there was NO knocking would it hurt the car
98 nizmo200sx se is offline   Reply With Quote
Old Jun 10th, 2003, 12:01 PM   #5 (permalink)
zeno
Paging Mr. Herman
zeno's Avatar
I'm guessing your ECU freaked out and automatically retarded the timing if you twisted it all the way. If you really want pinging, drive the car hard and see what happens. You are playing w/ fire, it only takes a small about of detonation to ruin your engine, do it right and put it at 15 degrees.
http://www.se-r.net/engine/about_tim...s%20it%20done?
Garage Sale - buy my junk!!
My Car!
Dreaming of turbo..... :fluffy:
zeno is offline   Reply With Quote
Old Jun 10th, 2003, 02:10 PM   #6 (permalink)
rkeith
rkeith's Avatar
hey zeno, are the timing instructions that you posted the same for my GA16? Im just curious cuz the directions mention the factory timing at 15* and I know that the GA16 is factory at 8*..... how do I compensate for this during the process?
Old Jun 10th, 2003, 04:43 PM   #7 (permalink)
LaRon
Well, I have driven it hard... quite hard last night and also today. It's running better than ever... a friend of mine told me I'd know it if I had detonation though and said that he thinks it's fine. What you guys think?
Old Jun 10th, 2003, 08:51 PM   #8 (permalink)
Katana200sx
P.O.S. Truckdriver
Katana200sx's Avatar
Send a message via ICQ to Katana200sx Send a message via AIM to Katana200sx
yes those instructions are the same for your ga. i have my timing set at 19 degrees...i turned it all the way towards the firewall bc i forgot the order of the timing marks and with the distr. all the way back it doesnt even register on the timing marks on the pulley if your gun is at 0...same thing if u retard it completely
Katana200sx is offline   Reply With Quote
Old Jun 10th, 2003, 10:36 PM   #9 (permalink)
sprayin200sx
Send a message via AIM to sprayin200sx
hey guys go to sentra.net and look up technical by mike kojima he knows his stuff and too much advance knocks the motor which will murder ur motor...dont do stuff half way cuz u mite regret it...do it rite...so check it and look at other stuff there and a lot questions can be answered....
"Got Boost?"
sprayin200sx is offline   Reply With Quote
Old Jun 11th, 2003, 02:41 PM   #10 (permalink)
bahearn
bitter old man
bahearn's Avatar
If you didn't set the ECU to timing lock mode when playing with the distributor, you've effectively done nothing as the ECU will retard timing to attain what it thinks is 8º BTDC.
If you DID achieve timing lock mode, then the ECU will retard timing as much as is needed to get the knock sensor to shut up...unless the distributor is so far advanced timing can't be retarded enough.
Bruce in Houston
bahearn is offline   Reply With Quote
