» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Old Apr 18th, 2003, 04:14 PM   #1 (permalink)
97sentragxe
I think I lost my mod-nes
97sentragxe's Avatar
problem when starting
I"m at my wit's end. I've tried everything I can think of:
My '97 Sentra, when I start it, fires right up, but immediately acts likes it's going to stall out, and then cathes itself and runs perfectly, like all Nissans. What could cause this hesitation?
It's got almost 94,000 miles. I've changed the plugs, wires, cap, rotor all within the last 2000 miles, and the battery a couple of thousand before that. There's no vaccuum leak, at least with pulling the PVC valve, I don't know of any other ways to check for vac. leaks. I know this isn't a major problem, and as long as my car is running well otherwise, I'm not really concerned about it, but I'd like to know if it's gonna get worse, or if its something I can fix to make it run perfectly well ALL the time. This problem has been going on for the past 5,000 miles or so, and its not getting any worse or any better no matter what I do.
THanks
Jason
97sentragxe is offline   Reply With Quote
Old Apr 19th, 2003, 06:15 PM   #2 (permalink)
azkicker0027
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
to chase a vacuum leak, use throttle body cleaner to spray up and around the intake manifold and vacuum lines, then observe for idle speed increase, and as always, did you check your idle air control valve??? clean it out or something.....
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://shop.3bspecialties.com/main.sc
azkicker0027 is offline   Reply With Quote
Old Apr 20th, 2003, 05:41 AM   #3 (permalink)
AznVirus
1.6 Turbo Power
Send a message via AIM to AznVirus
clean out you Idle Air Control Valve, its right next to the TPS. just unbolt it, use carb cleaner and a toothbrush and just start scrubbing.
and while you do that, might as well clean out your TB w/ the carb cleaner as well.
1.6 - The Underdog
GA16DE-T Owners Club!
153 HP & 152 TQ
AznVirus is offline   Reply With Quote
Old Apr 20th, 2003, 10:55 AM   #4 (permalink)
bgriffey
Guest
Posts: n/a
Re: problem when starting
IAC might be sticking...
Old Apr 20th, 2003, 02:20 PM   #5 (permalink)
Katana200sx
P.O.S. Truckdriver
Katana200sx's Avatar
Send a message via ICQ to Katana200sx Send a message via AIM to Katana200sx
when we got my friend's stang put back together yesterday it would stall out and wouldnt idle...problem was the tps. before that it was a mass air going bad. maybe check these out as well if it isnt the iac
Katana200sx is offline   Reply With Quote
