Old Apr 11th, 2003, 12:37 PM   #1 (permalink)
fastmode
Posts: n/a
Unhappy Blinker (Turning Signal) HELP!!!
Hi,
I have a '96 200SX SE-R, the problem is that after fixing my signal problem is has come back and I can't find what's wrong with it. When I signal to turn left the blinker comes up as normal, but when I turn on the left blinker, its blinks at hyper speed and really annoys me. Is there anyone out there that knows how I could get it back to normal. Thanks.
Old Apr 11th, 2003, 01:36 PM   #2 (permalink)
HATEnFATE
Because Size Matters
HATEnFATE's Avatar
Send a message via AIM to HATEnFATE
Most of the time a blinker will go faster because of a burnt out light bulb. jhave you checked all your lights??
If it's not that then you might need to replace your turn signal relay. They're relitivley cheap but start with the Bulbs, Go from there.
If you are trying to get faster on a track you will go off course. The question is where, and how bad..............
JAY
www.ilovetoargue.com
HATEnFATE is offline   Reply With Quote
Old Apr 11th, 2003, 08:35 PM   #3 (permalink)
jdub
I have the same problem, too, and both my blinker lights work fine. I did notice some condensation in my left corner...would that cause it?
jdub is offline   Reply With Quote
Old Apr 11th, 2003, 08:40 PM   #4 (permalink)
Teknokid
Boost anyone?
Teknokid's Avatar
Send a message via AIM to Teknokid Send a message via Yahoo to Teknokid
Re: Blinker (Turning Signal) HELP!!!
Originally posted by fastmode
Hi,
I think this is a typo. Im pretty sure its a burnt out bulb.
Chris
My ebay listings
Tekno AutoHaus
Originally Posted by Altim8GA
Does it really matter? That car is so visibly loud, a deaf mute starts to cuss it 2 exits away.
Teknokid is offline   Reply With Quote
Old Apr 11th, 2003, 10:20 PM   #5 (permalink)
faithandfame
Nissan Fanatic
faithandfame's Avatar
Send a message via AIM to faithandfame
I saw that you mentioned about your left blinker going really fast. I have the same problem with my car. I have replaced the bulb and everything, but it continues to blink really fast at random times.
your car may be faster, but my car is louder
just because im a girl doesnt mean i cant be into my car
faithandfame is offline   Reply With Quote
Old Apr 11th, 2003, 10:29 PM   #6 (permalink)
Smahatma
blinks very fast when theres a decrease in resistance, i.e. burnt out bulb, harness disconnected, wire was cut, etc.
Smahatma is offline   Reply With Quote
Old Apr 11th, 2003, 11:14 PM   #7 (permalink)
landlord
pay your rent!
landlord's Avatar
mine does it to, except that my front passanger side light only works when the parking lights are on. i know its a short or a bad ground, i just hav'nt had the time to look into it.
95 200sx timing advanced to 15*, custom cai, Stromung exaust (no cat), b&m short throw shifter, rusted out fenders, worn suspension, creaking balljoints, cracked windshield and bad cv axles. your regular hooptie that requires 92 octane.
landlord is offline   Reply With Quote
Old Apr 12th, 2003, 12:25 AM   #8 (permalink)
jdub
"blinks very fast when theres a decrease in resistance, i.e. burnt out bulb, harness disconnected, wire was cut, etc."
Strange...the lights work fine. No bulb burnout, nothing cut. Just an annoyingly fast blinker...not as fast when the lights are on.
Old Apr 12th, 2003, 10:10 AM   #9 (permalink)
landlord
pay your rent!
landlord's Avatar
same as mine.
Old Apr 12th, 2003, 08:06 PM   #10 (permalink)
sethwas
what?
sethwas's Avatar
Well,
If there was a past problem, your blinker relay may be shot. You could always shell out $10 for a new one, but thats a silly way to see if thats the root of the problem. (I did it once for a hazard trelay issue, and it worked like a charm, but it was a $10 gamble).
Seth
my signature is at the bottom of this thread. its because its too long. Lots of important links there.
http://www.nissanforums.com/showthread.php?t=46259
sethwas is offline   Reply With Quote
Old May 9th, 2003, 08:54 PM   #11 (permalink)
UNISH25
Flux Capacitor is the key
UNISH25's Avatar
Send a message via AIM to UNISH25
It is most likely a burnt our resistor or bulb somewhere within the car. Your relay is working fine, whats wrong here is the timing of the relay.
The timing of the relay is dependant on the resistors attached to it...So I'm assuming it is something wrong with the bulb or a resistor has been shot somewhere in your car. It could...quite possible(but rarely be the relay as well). If it was the relay then what would happen is your turn signal would be lit constantly or not be lit at all..
Electrical Engineer in da his house.
"If you eliminate the impossible then whatever left, however improbable must be the truth!"
UNISH25 is offline   Reply With Quote
Old May 9th, 2003, 08:56 PM   #12 (permalink)
UNISH25
UNISH25's Avatar
Condensation in your left corner???? Hmmm....thats weird....That could defenitly be a problem. Water could defenitly short circuit something, even if it is condensation.
Old May 9th, 2003, 09:20 PM   #13 (permalink)
dry
NF's Offical Post Whore
dry's Avatar
Send a message via ICQ to dry Send a message via AIM to dry Send a message via MSN to dry Send a message via Yahoo to dry
check your tail lights too... when my tail light turn was unplugged the front blinked hyper fast... the short or bad bulb could be back there.
dry is offline   Reply With Quote
Old May 9th, 2003, 11:28 PM   #14 (permalink)
IXLR8se-r
Send a message via AIM to IXLR8se-r
haha i have the same problem.. who knows what it is.. turn signal ghost
-- Howard
-- Aim: Superbrd15
-> JDM clear headlights w/ integrated city lights
-> WAI, JWT S4 cams, HS 5th gen header, high flow
-> cat, 15 degrees BTDC.
IXLR8se-r is offline   Reply With Quote
Old May 9th, 2003, 11:32 PM   #15 (permalink)
UNISH25
UNISH25's Avatar
Damn if only I had that stupid Chiltons guide...I could check out where the relays for the turn signal are!
