Old Mar 15th, 2003, 09:09 PM   #1 (permalink)
MCHNHED
Nissan Fanatic
MCHNHED's Avatar
Best Engine Oil????
Hey guys.... I have a '96 Nissan 200SX with the GA16DE motor. The engine has about 119,000 miles on it and i was wondering
WHAT IS THE BEST BRAND, TYPE, AND WEIGHT OIL TO USE?
i currently use 10W-30 Castrol GTX High Mileage and it runs wonderfully. Is there a better brand/type/weight to use?????
Also.... i am adding a TURBO this summer, running about 8-10 psi. What oil would ya suggest i use then? same one? what parts would you suggest i replace to prepare for it (other than the clutch)?
thanks guys.
MCHNHED is offline   Reply With Quote
Old Mar 15th, 2003, 09:38 PM   #2 (permalink)
myoung
NPM Lead Editor/Webmaster
myoung's Avatar
Mobil 1
myoung is offline   Reply With Quote
Old Mar 15th, 2003, 10:23 PM   #3 (permalink)
himilefrontier
265k miles and counting..
himilefrontier's Avatar
Send a message via AIM to himilefrontier
Only bad thing about the Mobil 1 in my experience has been if you switch to it in an older engine,it may cause the seals to leak because of the strong detergent package in it.A friend of mine put it in his 92 Pathfinder,and he had to replace the rear main seal shortly thereafter(but I have used it for years in my Frontier with no problems even after 192k mi).You definitely would want it in a turbo application because it is more resistant to breakdown than a conventional oil.
1998 Nissan Frontier XE/2wd/5spd 1 owner, 264k miles
1985 Olds Cutlass, 350 Chevy, owned for 14 years
WANTED: 1968-1973 Datsun 510 or 1991-1994 Sentra SE-R
http://www.myspace.com/junkyardengineer
himilefrontier is offline   Reply With Quote
Old Mar 15th, 2003, 11:08 PM   #4 (permalink)
zeno
Paging Mr. Herman
zeno's Avatar
Agreed....Mobil 1 is the best oil but I won't recommend it on such a high mile engine unless it has consistantly been given Mobil 1 in the past. The ironic thing is, the crappy oil that people use actually sort of creates a seal w/ all the residue the oil leaves behind in the engine. Mobil 1 will clean all these crap out but as a result your engine will start to leak. You may get lucky but this is the conventional wisdom.
Garage Sale - buy my junk!!
My Car!
Dreaming of turbo..... :fluffy:
zeno is offline   Reply With Quote
Old Mar 15th, 2003, 11:41 PM   #5 (permalink)
sentrapower93
Nissan Addict
After 10 years & 110k miles, using only Mobil 1 5W30 and a nissan oil filter has kept my 1.6 running like new...
06 1.8s SE Radium: Nismo stb,Nismo rsb,aFe drop-in,HKS Sport catback,tint, 17" Racing Sparcos, Falken ze-512s.
sentrapower93 is offline   Reply With Quote
Old Mar 16th, 2003, 12:20 AM   #6 (permalink)
himilefrontier
I've run it since it was a year old and only had 60k on it, but my friend's car had 90k and was 9 yrs old, that's why it leaked
Old Mar 16th, 2003, 01:02 AM   #7 (permalink)
Katana200sx
P.O.S. Truckdriver
Katana200sx's Avatar
Send a message via ICQ to Katana200sx Send a message via AIM to Katana200sx
ive ran mobil 1 since about 110,000. i had a front main seal that was bad...when i ran 15w-50 it didnt leak more than normal...switched to 10w-30 and it bled like hell. id recommend using any type of systhetic such as red line, royal purple, mobil 1. but mobil is more cost effective and you can buy a 5 quart jug at walmart for less than $20
Katana200sx is offline   Reply With Quote
Old Mar 16th, 2003, 02:34 AM   #8 (permalink)
zeno
Paging Mr. Herman
zeno's Avatar
If I remember correctly, it is something like 90k when they say not to use Mobil 1 unless you have used it for most of the engine's life. Correct me if I'm wrong.
Also keep in mind that Mobil 1, Royal Purple, etc. is not cheap. I pay about $40 on Mobil 1 oil alone per oil change.
My Car!
Old Mar 16th, 2003, 07:19 AM   #9 (permalink)
Centurion
freakish poster
Centurion's Avatar
Mobil1 since new, 144K miles ago, runs beautifully, with NO leaks whatsoever. Changed every 5K.
Centurion is offline   Reply With Quote
Old Mar 16th, 2003, 02:00 PM   #10 (permalink)
LIUSPEED
Vendor
DNE's VZR Conversion
LIUSPEED's Avatar
Send a message via AIM to LIUSPEED Send a message via MSN to LIUSPEED Send a message via Yahoo to LIUSPEED Send a message via Skype™ to LIUSPEED
i use Vavoline Durablend...
no problems here.
LIUSPEEDTUNING.COM Get your new headlights,corners here !!
Click here to get great quality HID's here for a really good price!!
LIUSPEED is offline   Reply With Quote
Old Mar 16th, 2003, 08:59 PM   #11 (permalink)
Gimp
What's the point?!
Gimp's Avatar
Royal Purple. Noticed quite a difference the first few oil changes. ALTHOUGH, I do the oil changes myself and I don't mind spending $20 for the oil and $5 for the filter.
I Don't CARE!!
Gimp is offline   Reply With Quote
Old Mar 16th, 2003, 09:17 PM   #12 (permalink)
Teknokid
Boost anyone?
Teknokid's Avatar
Send a message via AIM to Teknokid Send a message via Yahoo to Teknokid
Mobil 1 5w30. Havent had any problems since ive put it in. Previous owner also used Mobil 1.
Chris
My ebay listings
Tekno AutoHaus
Originally Posted by Altim8GA
Does it really matter? That car is so visibly loud, a deaf mute starts to cuss it 2 exits away.
Teknokid is offline   Reply With Quote
Old Mar 16th, 2003, 10:51 PM   #13 (permalink)
Katana200sx
P.O.S. Truckdriver
how are you spending $40 on just oil per oil change? just go to walmart and buy it man. i havent had any leaks since i changed my front main seal.
Old Mar 17th, 2003, 01:16 AM   #14 (permalink)
zeno
Paging Mr. Herman
zeno's Avatar
Mobil 1 is about $5 a quart where I'm at.
My Car!
Old Mar 17th, 2003, 01:39 PM   #15 (permalink)
togenji
Send a message via AIM to togenji
Since the season is starting to heat up, would you guys stick with 5w-30 or switch to 10w-40?
1998 200sx 1.6 Hotshot Cold Air Intake, UR pulley
My site
togenji is offline   Reply With Quote
