Old Jul 28th, 2007, 05:41 PM   #61 (permalink)
happykorn
Send a message via AIM to happykorn
ok so i read thru this thread, and have a question.
I just did my first oil change, and put in Mobil 1 10w-30. I see alot of people have had leaks, and some haven't. So if i do get a leak from switching from whatever Goodyear uses to Mobil 1, how long would it take for a leak to appear? Is there no way of really telling and it would depend on the car? Anyways Thanks
happykorn is offline   Reply With Quote
Old Jul 29th, 2007, 04:19 PM   #62 (permalink)
wellitsovernow
Send a message via Yahoo to wellitsovernow
??? you will be good with mobil 1 I used for years in every car i own and in my opinion its the best oil that can be bought from anywhere. i will be using Redline soon but that has to be shipped here.
97 200sx - t28 bb turbo, JWT ecu, 72lb inj, cobra maf, CP pistons 86.5mm, rebuilt head with port, 3" full exhaust, poly motor mounts, 12x24x3" intercooler with 2.5" piping, Nx2000 brake upgrade, Nitrous express Wet system, and more.
04 350z
wellitsovernow is offline   Reply With Quote
Old Apr 19th, 2008, 01:53 PM   #63 (permalink)
larry164
Amsoil all the way been running it for 8 yrs now in my 2000 Frontier also run amsoil in the tranny and rear end. awesum stuff.
Also ran Amsoil prior to my Nissan in a 89 Blazer for 11 yrs. 328,000 mi. never had an engine or tranny problem.
larry164 is offline   Reply With Quote
Old Apr 20th, 2008, 12:31 AM   #64 (permalink)
sunny441
All i use is Federated Regulated 15W40 , with a NAPA GOLD filter and I live in Michigan.
I am considering switching oil to a synthetic but am not sure what grade and whether i might have problems with leaks and such!
cheers
sunny441 is offline   Reply With Quote
Old Apr 20th, 2008, 01:35 AM   #65 (permalink)
sportcoupe(turbo)
sportcoupe(turbo)'s Avatar
Send a message via MSN to sportcoupe(turbo)
mobile 1 is the only oil that is true synthetic all other brands that are reached in a store are not synthetic they might have 10% synthetic oil in it. I do not see the point in switching to mobile 1 if you do not have a turbo but would recomand changing oil regularly depending on driving conditions and habits 10w 30 = summer 5w 30 = winter one way to see if your overdue or ok when changing oil and some light goes trough it when its coming out your a tad late if no light comes through very late if oil has a smell of gasoline you need to change it rite away ! hope this helps some of you guys and please dont change it 3 times a year thats just stupid the reason as to why you have a time interval and not just distance is because oil acts out as a filter as well filtering out surtain thing out of your engine.
1987 Nissan Sentra Sport Coupe
sportcoupe(turbo) is offline   Reply With Quote
Old May 10th, 2008, 07:05 AM   #66 (permalink)
maroonsentra
Nissan Fanatic
maroonsentra's Avatar
Originally Posted by Lucino200sx View Post
But you can't go wrong with Mobile. If you really really want to take care your engine,change your oil frequely, like every 1500 or 2000 miles, it doesn't really matter what type of oil you use. Trust me.
This is dumb. Oil doesn't even break down in 5,000 miles. Changing before 3,000 is a waste. I have an article on this if you want to see it.
maroonsentra is offline   Reply With Quote
Old May 13th, 2008, 01:26 AM   #67 (permalink)
Captain Obvious
Oh Ya
Send a message via Yahoo to Captain Obvious
we have actually been talking about this since 2003? my goodness
and for the record oil does not break down its the additaves in the oil that break down.
there are so many different things that can effect this and changing your oil 3000 miles is safest.
however honda a couple years ago ut out a TSB that said that changing the oil in thier cars every 3000 miles was not needed and they recoment 5000 miles.
problem is that you cant go off that you can only go off the maker of the oil and not the car maker.
I am currently using my 2004 corolla as a test platform for an amsoil xl product tha tadvertises 7500-12000 mile changes
I currently change it at 10k and when I hit 100k I will check remeasure the engine and go against the pre measurments I did when the car was new
oh and changing from Dyno oil to a syn oil WILL NOT produce leaks,this is a myth and I have found it untrue.
however if you do get an oil with a higher detergent concentration then you may clean the crap out that will show leaks that was already there just hidden by gunk.
but if you have an otherwise good car and you switch it at anytime from conventional to synth you will be fine
I's scratches ma hea' den sniff it.
Captain Obvious is offline   Reply With Quote
Old May 13th, 2008, 10:41 AM   #68 (permalink)
IanH
Post Freak
IanH's Avatar
I agree, Absolutely true !!!
Yes but a myth founded in truth from the earliest Synthetics.
As I understand it the first synthetics caused leaks. How?
Well the Conventional oil caused the rubber seals of the day to swell, that took up wear and prevented leaks from seals and gaskets.
When the switch was made to synthetics the rubber returned to its normal size. Leaks then appeared. (think old Chevy small blocks !!)
So the Synthetic manufacturer added additives to produce the same amount of rubber sweling as conventional oil.
So it was no longer a problem, but the stories persist.
So don't worry about leaks, I haven't had any switching over on my 10 yr old Sentra !!
1997 Sentra GXE .... SOLD
1997 S-ER 5 sp yea !!!
2003 Pathfinder SE 4WD
IanH is offline   Reply With Quote
Old May 13th, 2008, 04:21 PM   #69 (permalink)
wolfeyes
Hey guys, quick question, I've been running Valvoline Max life Synthetic every 3 months on '03 Max,SE. Since I drive around 600 miles per month can I extend the changes to every four months instead of three? Don't want to give the dealership any more money than they need.
Thanks
wolfeyes is offline   Reply With Quote
Old May 13th, 2008, 05:04 PM   #70 (permalink)
fatboy98maxima
fatboy98maxima's Avatar
10w 30 works fine to me
fatboy98maxima is offline   Reply With Quote
Old May 15th, 2008, 05:21 PM   #71 (permalink)
SentGXE99
Powered by natural gas
SentGXE99's Avatar
I have been using Walmart Super Tech 5w-30 w/ the Walmart filter because my Sentra is my daily driver/ beater. No problems at all, no burning oil, no leaks, 4 years and 100k since I got it now. I usually change it every 5k, and occassionally add some lucas oil treatment. I am also never wrong, so you can trust me. People sometimes tell me I'm wrong, but this leads me to conclude they are all wrong, thus making me doubt humanity's honesty. Walmart synthetic oil is fine for a Sentra. No, I don't work for Walmart, I actually hate Walmart, which makes this a bittersweet irony.
What would Brian Boitano do, if he were here today?
I'm sure he'd kick an ass or two. That's what Brian Boitano would do.
SentGXE99 is offline   Reply With Quote
