98 Sentra Fuel Pump Location - Nissan Forum
post #1 of 13 Old Jan 14th, 2012, 07:18 PM Thread Starter
Send a message via AIM to crazy101101
Hi Everyone,
I am trying to locate the fuel pump relay on my car. The car will not run, and is not getting any fuel. I checked the fuses, but I am not getting any voltage to the fuel pump. The service manual says there is a fuel pump, but I don't see it under the hood. Any ideas?
crazy101101 is offline
post #2 of 13 Old Jan 14th, 2012, 07:35 PM
NF Mod/Nissan Master Tech
smj999smj's Avatar
Fuel pump relay is behind the instrument cluster, according to ALLDATA. The fuel pump, itself, is in the fuel tank. If you remove the rear seat bottom, you will see an access panel to the fuel sender/pump assy.
smj999smj is offline
post #3 of 13 Old Jan 15th, 2012, 01:09 AM
jdg
The Judge!
Wait a minute...
[quote]I am not getting any voltage to the fuel pump[quote]
To recap:
Trying to locate the fuel pump relay.
Can't get any voltage to the fuel pump.
Can't find the fuel pump.
How does the O/P know there's no voltage at the fuel pump, if the O/P can't find the fuel pump?
99% of the questions that are "STRANGE" have a dirt simple answer...usually answered by a dirt simple search.
Is it just me, or does the majority overlook the obvious?
Somebody ate a whole bag of dumbass for breakfast.
Why do people continue to run a vehicle when a warning light comes on or starts flashing? Isn't that a clue that something is wrong and you probably should NOT drive it?
Is this whole car driving thing really freekin' brain surgery?
Here's something new for the crowd/clowns...
"A little bit of Google goes a long way!"
Ever notice the one post wonders for info on turbo'ing a GA16 are never heard from again after they figure out the cost???
And if you can read this, you don't need glasses! :)
And yes, I am diggin' it...
jdg is offline
post #4 of 13 Old Jan 15th, 2012, 03:10 AM
smj999smj's Avatar
I noticed that as well...but chose to just answer the question asked.
post #5 of 13 Old Jan 16th, 2012, 03:30 PM
EvilPotato's Avatar
Hi Everyone,
I am trying to locate the fuel pump relay on my car. The car will not run, and is not getting any fuel. I checked the fuses, but I am not getting any voltage to the fuel pump . The service manual says there is a fuel pump relay, but I don't see it under the hood. Any ideas?
is what i think he meant
"...and the Lord said to John, Come forth and ye shall receive eternal life, but instead John came fifth and won a toaster."
EvilPotato is offline
post #6 of 13 Old Feb 5th, 2012, 01:38 PM
Garage
The fuse is in the dash fuse panel near the driver's door low on the dash. I think it's a 10 amp fuse. Not sure but I bet the relay is in there too.
etepsnewo is offline
post #7 of 13 Old Mar 2nd, 2012, 04:17 PM
EvilPotato's Avatar
and the relay is right above that fuse panel, one of those blue relays, accessible once the panel for the cruise/mirrors/dimmer etc. is removed. or just crawl under the dash
post #8 of 13 Old Mar 15th, 2012, 08:39 PM Thread Starter
It was a little hard to get too, but I found it. Thanks for all your replies and help!
post #9 of 13 Old Jul 26th, 2012, 10:31 PM
I am having the same issue. I looked behind the cruise/mirror/dimmer and see 4 blue relay's. Which one is the fuel relay? I don't want to mess anything up by trial and error. Anybody know which one exactly?
97OldSchool is offline
post #10 of 13 Old Jul 27th, 2012, 08:01 PM
How far can I take it?
Jopet's Avatar
Send a message via Yahoo to Jopet
its below the dimmer and power window adjustment. Below, not behind. It has a cover that you can put two fingers in to pull out. The cover will have the description of the fuses.
Jopet is offline
post #11 of 13 Old Jul 27th, 2012, 11:22 PM
I located the fuses and I look in and up and see the relay's. I just don't know which relay is the fuel pump relay.
post #12 of 13 Old Jul 27th, 2012, 11:35 PM
EvilPotato's Avatar
i don't think it's any of those blue relays. i may have removed all 4 at once before trying to find which is for the instrument cluster and if i remember, the car still ran. i think all 4 are identical so no harm in pulling them and interchanging. the one on the top left is a bit tricky to pull out, need a small flat screw driver to pry the tab out before you can pull it out, same with the middle one, 2 bottom ones you can just pull out and push back in. good luck
post #13 of 13 Old Jul 28th, 2012, 01:05 AM
smj999smj's Avatar
The fuel pump relay is way up behind the dash by the crossbeam, in the area behind the instrument cluster. Not the most convenient place for a fuel pump relay!
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
