Links
Go Back   NissanForums.com > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Old Apr 19th, 2008, 12:48 PM   #1 (permalink)
filcchar
Unhappy Water leak behind glove box (need help)
Cheers,
Need some help here!
After a rainy day i found drops of water falling from behind glove box, in order to find the leak i took the garden hose and turn on the water for 15 minutes (and i gave the car a heavy bath) ... nothing happen, but when I started the car and drive for a while ... the carpet become wet under the A/C filter, so I took the glove box and found clean water leaking near the A/C filter...
Any ideas?
ps. sorry for the rusty english
filcchar is offline   Reply With Quote
Old Apr 20th, 2008, 01:19 PM   #2 (permalink)
IanH
Post Freak
IanH's Avatar
there is a drain pipe from the bottom of the A/C evaporator to drain water and this gets blocked.
Unblock it and the water will drain out normally, you see the puddle under the car after you park from the A/C
1997 Sentra GXE w/195/50 15's and AD22VF, Tach, Halo's, Front seal, Rear SER Disc Brakes
2003 Pathfinder SE 4WD
IanH is offline   Reply With Quote
Old Apr 20th, 2008, 08:07 PM   #3 (permalink)
joeli16
Nissan Fanatic
That's great help ianH.I am having this problem since the first day I own my sentra.I was thinking the seal around the hole for the blower motor is bad...it is underneath the plastic panel (same place for the wiper motor and the linkage).I have never thought about the A/C drain before...
joeli16 is offline   Reply With Quote
Old Apr 21st, 2008, 11:14 AM   #4 (permalink)
filcchar
Yeah thanks IanH I´ll try to find the drain... i guess its under the car near the wheel but i dont know for sure the spot and how to unblock it
Old Apr 22nd, 2008, 08:46 AM   #5 (permalink)
IanH
Post Freak
IanH's Avatar
Well i admit i haven't looked for it but normally it goes down behind the top of the carpet and out the firewall by the passengers feet. I will take a look at mine and let you know if i see it.
Old Apr 22nd, 2008, 07:28 PM   #6 (permalink)
filcchar
ok... i´ll try to find it this weekend.... i saw a black tube near the A/C filter but I don't know if it´s the one
Old Apr 28th, 2008, 06:48 AM   #7 (permalink)
aepineda
i have the same problem...and it happends more on rainy days...im gonna take a look right now...my girlfriend is upset becasue her feet got wet everytime and in the morning the cabin smells awful...
aepineda is offline   Reply With Quote
Old May 1st, 2008, 06:18 PM   #8 (permalink)
Divo25
Gig 'Em Aggies !!
Divo25's Avatar
Send a message via AIM to Divo25
*Bump* any one found exact location yet ?
http://www.cardomain.com/ride/2555618
Gig 'Em Aggies
Divo25 is offline   Reply With Quote
Old May 2nd, 2008, 08:47 AM   #9 (permalink)
IanH
Post Freak
IanH's Avatar
I looked and the rear of the control arm was wet, but i will have to get underneath to find it.
I looked in the FSM and cant find any mention of it, was hoping for a diagram i could post.
anyone else ?
Old May 2nd, 2008, 08:15 PM   #10 (permalink)
revoltrise
the a/c drain on sentra's, altima's, and just about every other nissan up to 2004 is near the bottom of the firewall on the right (passenger) side of the car...just a black rubber tube, nothing fancy. if your a/c drain is plugged, make sure you fix it ASAP, depending on your model the leaking water can end up on your ECM...and that's never cheap.
revoltrise is offline   Reply With Quote
