Old Feb 12th, 2008, 05:57 PM   #1 (permalink)
itchy5
Sunpro aftermarket tach problem
hi guys, first time posting here.
I recently purchased and installed a sunpro tach III on my 95 sentra XE and after i wired it to the ECM's blue wire (tach sensor) i turned on the engine and the RPM went to 4500 and stayed there. If i reved the engine sometimes it would drop to 2000 RPM for a second but always went back to 4500 untill i turned the motor off. I wired the dimmer, ground and power wires to my rear window defroster button on my instrument panel. Could a bad ground be the problem?
any help would be much appreciated thanks
EDIT: i tried the blue/orange wire, which is what i read was the tach sensor for the B14s on the tach write-up and i got nothing, it stayed at 0 RPM... i also heard the WHITE/BLACK At Pin #1 Can Also Be Used For Tach Signal. on the12volt.com, should i give that wire a try?
EDIT#2: the white/black wire got it.
itchy5 is offline   Reply With Quote
Tach Problem red 02 specv B14 95-99 chassis 1 Jun 3rd, 2006 09:33 AM
96 Altima head gasket/head/heat damage problem? 96AltimaOwner U13 1993-1997 Altima 0 Aug 20th, 2004 08:58 AM
aftermarket tach MELGUN Truck & SUV 1 Jun 22nd, 2004 02:39 PM
Factory tach problem Zach200 B14 95-99 chassis 1 Apr 30th, 2004 12:15 AM
Problem installing tach sentra97gxe B14 95-99 chassis 6 Apr 14th, 2004 08:22 PM
