Old Dec 19th, 2007, 07:29 PM   #1 (permalink)
tsquic
Rear o2 sensor bypass?? 1996 1.6 sentra
I have a 1996 Sentra GXE with a 1.6 engine. I recently damaged the rear O2 sensor by backing out of a driveway with a buckled piece of concrete. I recently replaced the header pipe(s) and cat with after market from Exhaust Warehouse.com. The center pipe and muffler are after market also. Well the system seems to hang lower than the factory system and the rear O2 sensor is angled down towards the ground a little more than the original system. The lower position of the O2 sensor and the buckled sidewalk combined to physically damage the O2 sensor causing the CEL to light. QUESTION: since the rear O2 sensor only tells the computer if the Cat is working, can it be bypassed by connecting the wires together?
Also, does anyone sell heavy duty rubber exhaust hangers for the 1996 Sentra? I have seen heavey duty hangers for VW made from polyurathane(?sp) over stainless cable.
tsquic is offline   Reply With Quote
Old Dec 19th, 2007, 10:39 PM   #2 (permalink)
2dr_Sentra
Mr. Ghetto Rig
2dr_Sentra's Avatar
Send a message via AIM to 2dr_Sentra
Yeah the rear o2 reads nothing more than cat efficiency. You can left it unplugged... you'll have a check engine light though. Ive been running a test pipe for years now with no problems.
1997 Nissan 200SX SE-R -Turbo Lowport, S4 cams, 3inch turbo back exhaust
2007 Versa SL 6 speed
1991 Nissan Sentra XE w/ 1.6L - sold :(
2dr_Sentra is offline   Reply With Quote
Old Dec 20th, 2007, 01:29 AM   #3 (permalink)
birdsflyingover
yeah, it just monitors the cat. you can't by pass it by connecting the wires(actually kind of a funny solution). it's 12 years old, run with the light on.
birdsflyingover is offline   Reply With Quote
Old Dec 24th, 2007, 11:31 AM   #4 (permalink)
Katana200sx
P.O.S. Truckdriver
Katana200sx's Avatar
Send a message via ICQ to Katana200sx Send a message via AIM to Katana200sx
kartboy makes exhaust hanger you can use on your b14. i did the same thing to my o2 sensor after installing a catco high flow convertor. if you trace the wire back to where it goes inside the chassis, you can unplug the wire hanging outside and then pop the grommet back on....then buy a bolt to plug the hole for the o2 sensor. it makes it a bit cleaner than just clipping the wire and leaving the old o2 sensor in there.
Katana200sx is offline   Reply With Quote
Old Jan 14th, 2008, 09:07 PM   #5 (permalink)
mcr_nismo
mcr_nismo's Avatar
and u guys have had no problems? wow. that shows how good of a car nissan makes....lemme xplain: o2 sensors feedback change the short/long-term fuel trim....without it the computer is not running off live-data and adjusting accordingly but off a look-up table.......this, essentially is jus a parameter in the computer with usable o2 readings already programmed that the computer uses. the problem is that without constant, changing readings u prob. won't get the best efficiency, but ur car will still run...just not the way it was designed....
mcr_nismo is offline   Reply With Quote
Old Jan 15th, 2008, 02:01 AM   #6 (permalink)
Katana200sx
P.O.S. Truckdriver
thanks for the explanation...but research how nissan, specifically the sentra, uses the rear o2 sensor. it is really only used in the emissions system. your car can run perfectly without the rear o2, and run like shit without the front.
Old Jan 15th, 2008, 01:25 PM   #7 (permalink)
mcr_nismo
mcr_nismo's Avatar
oh so they only use the front for reference? hm interesting. thanjs for that i didnt kno...well, im sure i couldnt remove it cuz of inspections in ny they'll prolly hav a fit!
Old Jan 15th, 2008, 08:21 PM   #8 (permalink)
azkicker0027
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
for emissions inspections, yes, you will have some issue, well, depending on the inspector or facility. i, myself have a free flow cat and i extended the sensor harness (sensor side) to accommodate the relocated cat. the ones that actually have the grommet on the under-body are mostly the 2.0L models.
i haven't had much trouble with my cat efficiency monitoring.
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://www.200sxonline.com/community/
azkicker0027 is online now   Reply With Quote
my 99 Gxe 1.6 is leaking oil, rear main maybe? DonaldHays B14 95-99 chassis 3 Nov 12th, 2005 09:31 PM
Rear shock replacement Sentra Sedan wine B14 95-99 chassis 1 Oct 11th, 2005 06:44 PM
1996 nissan sentra no start ken s GA16DE 1.6L Engine 7 Oct 6th, 2005 03:52 PM
B12 Sentra rear susp sinking problem nyit240 B11/B12/KN13 82-90 chassis 17 Sep 2nd, 2004 06:46 AM
Greddy SP Cat Back Exhaust for 94 1.6 Liter Sentra Sentra GTR-1 GA16DE 1.6L Engine 4 Aug 6th, 2002 06:35 AM
