Old Nov 4th, 2007, 04:38 AM   #1 (permalink)
arni 200sx
arni 200sx's Avatar
Exclamation **HELP** anti theft system went crazy !!
this morning when i came to enter the car, the alarm went off and wouldnt stop for a while. the car obviously wouldnt start.
it goes off whether i use key or keyless entry.
i tried disconnecting relays, fuses and what not.
HOW DO I DISABLE THE DAMN THING ?!?
1996 B14 200SX SE-R
arni 200sx is offline   Reply With Quote
Old Nov 4th, 2007, 10:23 AM   #2 (permalink)
scooterbob
Send a message via MSN to scooterbob
I realize that you are a fairly new user, so I did the searching for you. --> http://www.nissanforums.com/b14-95-9...lfunction.html
Follow those instructions and see if that helps you out. The search button can get you the answer a lot quicker than waiting on a reply. :-)
Good luck
2008 Versa!
'95 200sx S-er: Homemade intake w/filter, 91 cams, advanced timing, 4 ga. grounding kit. (possibly for sale now)
If you ain't pinging redline MOVE! ---Bob
scooterbob is offline   Reply With Quote
Old Nov 4th, 2007, 08:00 PM   #3 (permalink)
arni 200sx
arni 200sx's Avatar
eventhough i did use search, i didnt get to the thread you found
thank you !
1996 B14 200SX SE-R
Old Nov 6th, 2007, 04:57 PM   #4 (permalink)
scooterbob
Did you get it deactivated?
2008 Versa!
Old Nov 8th, 2007, 05:17 AM   #5 (permalink)
arni 200sx
arni 200sx's Avatar
yes sir, what seemed to do it eventually was locking the car, wait for the alarm to stop and then unlock the driver side door using the key.
1996 B14 200SX SE-R
Charging System FAQs blackmaxima88 B13 91-94 chassis 2 May 5th, 2008 01:13 AM
92 STANZA XE (alarm system problem) rufus New Member Forum 0 Nov 25th, 2005 11:17 AM
anti rust electronically Electro-Shield System ak47m203 Car Care 3 Jul 18th, 2005 11:17 AM
From teh FAQ section Marvin Off Topic 8 Nov 1st, 2003 11:26 PM
Top Ten Area For Car Theft LIUSPEED Off Topic 14 Jun 10th, 2003 09:37 AM
