Old Nov 3rd, 2007, 02:48 PM   #1 (permalink)
karson
97 sentra auto gear shift lever stuck
hi all,
I have a 97 sentra, works great.
The problem is when i try to shift gear ( automatic) when i start, i am not able to change gears. The small knob on geat shift that needs to be pressed by thumb wont depress at all.
After a few seconds, i can depress the small knob on shifter and then everything moves smoothly.
Another small issue is, car key gets stuck when after switching off car.
I normally restart the car and stop it, keys come out fine.
Not sure if these two are related.
Please help.
thanks
karson
karson is offline   Reply With Quote
Old Nov 4th, 2007, 07:29 PM   #2 (permalink)
azkicker0027
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
the inter-lock on the auto trans selector might be sticking. I'd have to check on that since i haven't dealt with this problem in a while.
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://www.200sxonline.com/community/
azkicker0027 is offline   Reply With Quote
Old Nov 5th, 2007, 06:36 AM   #3 (permalink)
karson
you are right, it is the shift lock
azkicker,
Please advise how you resolved this issue. This has become lottery to get to some place in time.
You are right, i checked the gear shift, seems like the small shift lock (solonoid) or inter-lock as you called it, it will not open completely i press on brakes. Shift lock does move a little, but now enough.
Now interestingly shift lock moves on its own when i press the little knob on gear shift, just a little is enough to make shift lever move the extra step.
I sprayed the shift lock solonoid and the small assesmbly with WD-40. Not much change, only a little better.
Thanks a lot
Old Nov 5th, 2007, 06:50 AM   #4 (permalink)
thezman
you sprayed an electric solonoid with w/d 40?
Towing broke down cars since 1999. Including primary for local Nissan, chevy, kia, Honda, dealerships.
thezman is offline   Reply With Quote
Old Nov 5th, 2007, 11:12 PM   #5 (permalink)
karson
i did use wd 40
I did sprayed it with WD 40, should i have not done that.
Auto Trans Won't Shift: How to test your transmission computer, 87-95 Pathy (FSM) striperdad Pathfinder 9 Mar 9th, 2007 05:44 PM
Help! Trans Stuck in 2nd (?) Gear! Curtis Sentra B13 91-94 chassis 2 Sep 2nd, 2006 09:25 PM
'94 sentra auto - won't shift, please help ogre B13 91-94 chassis 20 Feb 4th, 2004 09:30 PM
My auto Tranny: Mythical 4th gear? Rain-Xx E/CA-Series & GA16i Engines 9 Mar 23rd, 2003 06:54 PM
bent shift fork, or 5th gear replace? fsr20det B13 91-94 chassis 1 Feb 10th, 2003 11:59 AM
