Old Jun 20th, 2007, 03:19 AM   #1 (permalink)
ilikespeeding
A/C blows hotter air than ambiant!
My A/C is stupidly horrible on my sentra. This thing actually has the nerve to blow hotter air at me than it is outside. I checked the low pressure side while running. It was right between the blue and yellow on the self charge gauge (right where it's supposed to be). If it has pressure, then I have no idea why I dont have cold. Having pressure means I have refridgerant. Maybe there is a slow leak and all of the refridgerant is dry? This is why neither of my mitsubishis have any A/C system.
1990 Eclipse GSX - Money Eater
1996 Eagle Talon TSi - Wrong wheel drive
1996 Sentra GXE - Daily Driver
ilikespeeding is offline   Reply With Quote
Old Jun 20th, 2007, 07:43 AM   #2 (permalink)
oliverr87
Nissan Fanatic
Send a message via AIM to oliverr87 Send a message via MSN to oliverr87 Send a message via Yahoo to oliverr87
having pressure doesn't mean you have refridgerant.
oliverr87 is offline   Reply With Quote
Old Jun 20th, 2007, 03:16 PM   #3 (permalink)
ilikespeeding
...unless I have all oil...
That would be like having oil presure with no oil. I relieved the high pressure side with the car off and there was oil and I smelled refridgerant.
Old Jun 21st, 2007, 11:15 AM   #4 (permalink)
IanH
Post Freak
IanH's Avatar
That would be like having oil pressure with no oil. I relieved the high pressure side with the car off and there was oil and I smelled refrigerant.
You need to get a better set of gauges with high and low side pressure reading.
You have checked the compressor is actually turning ?
But for now, what is the Low side pressure with A/C off, running at idle and running at say 3000 rpm.
Do you see the compressor disengage and re-engage, what pressure readings.
Also does it work at a higher speeds on the freeway for instance ?
1997 Sentra GXE .... SOLD
1997 S-ER 5 sp yea !!!
2003 Pathfinder SE 4WD
IanH is offline   Reply With Quote
Old Jun 21st, 2007, 11:43 AM   #5 (permalink)
ilikespeeding
Actually. come to think of it, I dont hear clicks from it disengauging and enguaging. But, from the pulley, it's not locked up or anything.
Old Jun 21st, 2007, 11:56 AM   #6 (permalink)
IanH
Post Freak
IanH's Avatar
Ok the pulley turns, but does the clutch engage and turn the clutch plate (and compressor.)
If you don't have enough Freon pressure the clutch will not engage.
Old Jun 21st, 2007, 03:05 PM   #7 (permalink)
ilikespeeding
I thought it was electric?
Old Jun 21st, 2007, 03:13 PM   #8 (permalink)
IanH
Post Freak
IanH's Avatar
Not unless you have a Prius !!
The compressor is engine driven, and the clutch and controls are electric.
Old Jun 22nd, 2007, 02:06 PM   #9 (permalink)
ilikespeeding
I meant that I thought the clutch for the A/C was engauged by electic current. Since this car has had about 100,000 other things wrong electrically, Im going to see if there is current to the clutch.
Old Jun 22nd, 2007, 06:00 PM   #10 (permalink)
IanH
Post Freak
IanH's Avatar
The clutch will NOT engage if the pressure is too low, or too high !!
So if the clutch plate and center axis of the compresor aren't turning locked to the pulley its safe to say there is no current to the clutch.
the first thing to do is to measure the pressure in pounds/ sq inch and record the temperature. In the FSM will be the specs for the low side switch. If there is enough to activate the clutch then go ahead and start the car and watch the gauges,
good luck...
Air Conditioner will not shut off... Limey L31 2002 - 2006 36 Sep 25th, 2005 02:45 AM
yet another blower motor thread Hyunduzu B13 91-94 chassis 6 Jul 20th, 2004 08:18 PM
A/C not blowing cold air... McLaren F1 2003 B14 95-99 chassis 4 Mar 25th, 2004 06:38 PM
air conditioner noise lownissan dj Truck & SUV 4 Dec 8th, 2003 09:59 AM
91 Sentra 4dr E - A/C Compressor SpongeBob-RC B13 91-94 chassis 1 Jul 7th, 2003 01:14 PM
