Old Jun 6th, 2007, 09:59 AM   #1 (permalink)
GA16DEKID
Odd Problem. Help!!!!!
Hey guys I was driving last night and suddenly my battery light and e-brake light came on the bottom of the cluster. I tried stepping on the accelerator and there was resistance, but RPM's would not go up and the engine would not even rev. My car then just died. I tried starting it back up and nothing. It would turn over but would not start. I had noticed for a couple weeks it had been a little jerky when I would try and accelerate. After about ten minutes it started and away I went. WTF????? Air filter, fuel filter, battery cables????? Any help would be much appreciated. Thanks guys
Danny
GA16DEKID is offline   Reply With Quote
Old Jun 6th, 2007, 12:39 PM   #2 (permalink)
topz
Your alternator (charging system) is going south. Possibly the battery, or cables. Start checking the easy/cheap ones (cables, connections), then battery, alternator.
topz is offline   Reply With Quote
Old Jun 6th, 2007, 02:24 PM   #3 (permalink)
Burn 17
Nissan Fanatic
Burn 17's Avatar
Send a message via MSN to Burn 17
it could be the relay that turns on your alternator, that would explain a crank but no start, typicaly cars will not start without the alternator relay in working order, yours may be going bad, other than that i would have to say start cheakin voltages and resistances, your carging system is bad, OR!!!!!!!!!!!!!! you bought a crappy napa alternator or equvilent, in these the dioed trio and rectifier bridge (turn the voltage to dc from ac) have a tendancey to go bad and begin to make to much ac volts, you can see if this is it with a dvom first test it on ac volts then on dc volts. do this right from the alternator where the wires conect. or if you have acess to a microvat or d-tach use thoes, they are just luxuries tho
well do that and guv us the reslts well help you out some more
NEW!!1987 300ZX
200 sx auto cross beast--
Intake, Front and Rear Strut bars, Major exhaust leak.98style tail lights, clear corners, and halo angle eyes, Hot Shot headers/Downpipe(still need money for the rest of it)
Mazda B2200 Mini Truck
Burn 17 is offline   Reply With Quote
Old Jun 6th, 2007, 04:19 PM   #4 (permalink)
Tavel
Destroyer of worlds.
Tavel's Avatar
Send a message via AIM to Tavel
I would have to second it sounds like a bad alternator or similar.
alternators seem to be one of those items you have to buy from the dealer because the autozone parts just don't last (though you do get a lifetime warranty, so free replacements...but you'll replace it a lot)
I'll edit YOUR signiture!
Tavel is offline   Reply With Quote
Problem starting 1999.5 Pathfinder LE ninoj Pathfinder 7 Jul 4th, 2006 10:19 PM
Odd problem pete2.0 GA16DE 1.6L Engine 3 Jan 31st, 2006 08:08 PM
Odd problem Haywire Truck & SUV 5 Apr 14th, 2005 12:12 AM
Engine idle freaked out, went right back to normal sfhellwig GA16DE 1.6L Engine 27 Oct 24th, 2003 01:40 PM
97 Pickup EGR problem viper2 Truck & SUV 11 Aug 30th, 2003 06:27 AM
