siphoning fuel out of tank - Nissan Forum
post #1 of 4 Old Apr 13th, 2007, 01:58 PM Thread Starter
Purchased a plastic siphoning kit at the parts store. Pushed the clear tube thru gas filler opening but it seems to be bumping into something. 97 Sentra 1.6.
Called manufacturer. They told there may be a ball that prevents fuel spilling during rollover. Is this true?
Are there suggestions on how to siphon out the fuel?
Like when replacing the fuel filter?
Thansk
wine is offline
post #2 of 4 Old Apr 13th, 2007, 10:15 PM
Why would you need to siphon the fuel out? just put a clamp on the input side of the filter and pull out the old filter and put a new one in. No need to drail the whole tank.
redser is offline
post #3 of 4 Old Apr 15th, 2007, 06:00 AM Thread Starter
reason
Because there is a quarter of a tankful of gas (2.5 gal) sitting there in GA winter sitting there 3 months while out of town. The car won't start so it may need a new fuel pump.
I don't know but it may have bad gas and to be safe I don't want gas in the tank while replacing the pump.
Thanks
wine is offline
post #4 of 4 Old Apr 15th, 2007, 09:46 AM
The manaul says to releive the fuel preasure first. Pull the fuel pump fuse and start the car. It will run for a little bit then die, after that crank it a couple of more times. After that it says you can just replace the fuel pump. Once you get it out it might be easier to get the rest of the fuel out since there is not much in there.
You could also fill the rest of the tank with new gas and put a fuel treatment in it as well. This usually works for me.
Good Luck
redser is offline
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
OBD II Code Chart no1see2me QG18 1.8L Engine 9 Jul 26th, 2009 03:26 PM
91 NX1600 dies while running then wont start for 2 days, then starts and runs fine triplefour B13 91-94 chassis 0 Sep 16th, 2006 06:11 PM
difficulty pumping fuel into tank blissland B14 95-99 chassis 6 Oct 11th, 2005 04:31 PM
1990 Pickup: Fuel tank capacity? druid Truck & SUV 2 Jan 17th, 2005 09:24 PM
clean fuel tank...help manjula B11/B12/KN13 82-90 chassis 0 Feb 8th, 2004 10:51 AM
You may post new threads
You may post replies
BB code is On
