Old Mar 13th, 2007, 09:57 PM   #1 (permalink)
TMWTMP100
Help Diagnosising a Idling Problem
Ok, so I just got a '96 200sx se-r and there has been extensive modifications done to it (engine swap, cams, the whole 9) so Im happy with that.
The problem comes when I turn the car on. With the O2 sensor hooked up, if I turn the car on, it will turn on and shut right back off. Then I have to rev it up above 2500 rpm, and then it will idle for a little bit. After everything gets up to temperature, the idle wont hold steady and then itll finally die. Without the O2 sensor, I can crank it and it turns on and idles fine...until it warms up and then the idle is unsteady and it'll die.
What I was thinking was adjusting the idler screw so that it would idle at 1100 rpm, cause around there it was fine and the car didnt shake (when it does settle and it idles around 600 or 700 rpm, everything on the car shakes horribly). But I did a search and its not easy to get to the screw so I wanted to see if anyone else has had a similar problem first.
The engine is a DET out of a bluebird.
TMWTMP100 is offline   Reply With Quote
Old Mar 15th, 2007, 06:17 PM   #2 (permalink)
TMWTMP100
No one has an answer?
Old Jul 29th, 2007, 12:51 PM   #3 (permalink)
AndysSr20de7185
did you check all the air hoses/vacuum hoeses going to the intake? it could be a hose being loose or a broken hose at that.......
AndysSr20de7185 is offline   Reply With Quote
Old Jul 30th, 2007, 10:16 AM   #4 (permalink)
wellitsovernow
Send a message via Yahoo to wellitsovernow
Any codes? First check all your vac hoses and look for leaks on the intake. do a tuneup wires, plugs, fuel filter, o2 sensor. take a voltmeter and start checking stuff MAF, tep sensors ect.
97 200sx - t28 bb turbo, JWT ecu, 72lb inj, cobra maf, CP pistons 86.5mm, rebuilt head with port, 3" full exhaust, poly motor mounts, 12x24x3" intercooler with 2.5" piping, Nx2000 brake upgrade, Nitrous express Wet system, and more.
04 350z
wellitsovernow is offline   Reply With Quote
Weird starting problem.... dexkun B14 95-99 chassis 12 Jun 16th, 2007 07:46 PM
1997 pickup idling problem Jake11 Truck & SUV 13 Dec 7th, 2005 12:22 AM
NX2000 Cold Start Problem Seeking Help lucifer SR-Series Engines (DE/VE) 4 Mar 4th, 2005 08:18 AM
Idling problem mockus GA16DE 1.6L Engine 1 Nov 21st, 2004 08:18 PM
Idling problem tlyons Truck & SUV 1 Apr 1st, 2004 08:55 AM
