Old Jan 1st, 2007, 05:59 PM   #1 (permalink)
smileygirl921
97 Sentra Speed Sensor
(Trouble taking sensor out). I am trying to replace the gear oil in the manual transmission of my 97 Sentra. I believe the best way to do this is through the speed sensor. I have taken the bolt out but the sensor will not come up. Is there a trick (clip, prying, threads) to pulling it off?
smileygirl921 is offline   Reply With Quote
Old Jan 1st, 2007, 08:37 PM   #2 (permalink)
azkicker0027
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
well, yeah. you could go through the speed sensor hole, or at the 3/8" drive plug facing the radiator and fans. the drain plug on the other hand is the 1/2" drive plug on the lower end facing the driver's wheel. let me see if i can find some pics.
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://www.200sxonline.com/community/
azkicker0027 is offline   Reply With Quote
Old Jan 1st, 2007, 09:18 PM   #3 (permalink)
WhatDah
I just changed mine gear oil with Redline MT-90 over the xmas weekend. the speed sensor plug was a bitch to get it out. I just kept pressing it down and pulling it up(real hard) for about a min or 2, and it came up.
WhatDah is offline   Reply With Quote
EVAP canister vent control valve closed large168 SR-Series Engines (DE/VE) 32 Oct 3rd, 2008 03:11 PM
Sentra Spec-V Electronic Throttle Control Sensor...thingy.... jiggydragon Dallas Nissan Enthusiasts 9 Jul 1st, 2005 02:49 PM
Speed sensor wire for nav unit gelanni X-Trail 2 Jan 26th, 2005 04:38 AM
vehicle speed sensor cel catfixer GA16DE 1.6L Engine 2 Nov 15th, 2004 06:28 PM
Need some FSM info about speed sensor lovemyser B13 91-94 chassis 2 Apr 5th, 2003 10:14 AM
