Old Dec 24th, 2006, 04:31 PM   #1 (permalink)
CoffeeMed
98 Senta starting problems
My niece has a 1998 Senta GLE (hope this is right forum) and over the last 2 years has had starting problems. About every 2/3 months it turns over but does not start, she has it towed in to the dealship and then it starts. They claim she just flooded it, but she never steps on the gas while trying to start it. Then 2/3 months later it happens again, same thing. Right now it is sitting in her driveway from not starting yesterday and still wont start today. Any suggestions??
CoffeeMed is offline   Reply With Quote
Old Dec 24th, 2006, 07:06 PM   #2 (permalink)
ConKBot of Doom
I have heard this as a suggestion, but I'm not sure if it works in all the years of the sentras, push the gas to the floor, and try to crank it over. I believe its how you can 'tell' the ecu that the engine is flooded.
If that doesnt work pull the fuel pump relay or fuse, crank it for a bit, put the relay/fuse back in, and have a shot.
ConKBot of Doom is offline   Reply With Quote
Old Dec 24th, 2006, 10:43 PM   #3 (permalink)
mech361
Ninety-five through ninety-nine GA16 engines only had one compression ring, and were very easy to flood. I've found, more often than not, that the curb idle and ignition timing are ususally the culprits. Have the dealer set both to specs using the handheld computer (Consult 1 or Consult 2) that they have. This computer locks down idle speed and the ignition timing so they can be set properly. You can unplug the TPS to get the same effect, but the check engine light may come on.
mech361 is offline   Reply With Quote
Old Dec 26th, 2006, 07:59 AM   #4 (permalink)
PTXer
What I have found that if I moved my 97 around a couple times say juggling some cars in the driveway, starting it then quickly shutting it down without letting it warm up, it indeed won't fire the next morning. It is, I think, basically flooded like those previously guessed. Probably due with the emissions systems and the fact that the car wasn't allowed to warm up. I would then have to crank (and crank and crank) the car with the gas to the floor. It would finally start to sputter then turn over (lots of fumes too). It just takes alot of cranking. If I ever start my car to move it more than once, I let it warm up to operating temp.
Tom
PTXer is offline   Reply With Quote
Old Dec 27th, 2006, 06:28 AM   #5 (permalink)
LONDONDERRY
Nissan Addict
LONDONDERRY's Avatar
Sound to me the starter is going
LONDONDERRY is offline   Reply With Quote
Old Dec 28th, 2006, 11:38 AM   #6 (permalink)
1941Galant
Tom
I had that happen to me too. If I either moved my car in the driveway real quick, or let it sit for 4+ days it would start, sputter, die and then I would have to keep cranking it until it fired up. I took off the IAC (AIC?) on the throttle body and cleaned it out, and put a new fuel filter on and haven't had the problem since.
1941Galant is offline   Reply With Quote
Old Feb 18th, 2007, 11:41 AM   #7 (permalink)
juny-ser
hello thir am new in this forums i hope to mack new friends in her .
juny-ser is offline   Reply With Quote
Starting problems Nismo14-180 S13 240SX 1989-1994 1 Oct 10th, 2005 11:20 PM
Starting Problems PLZ help adamgdt SR-Series Engines (DE/VE) 0 Aug 11th, 2005 06:41 PM
Starting Problems/ Fuel injector and ECM.....Help!! seaofprajna U13 1993-1997 Altima 3 Jul 25th, 2004 01:07 PM
90 Sentra starting problems Enygma B11/B12/KN13 82-90 chassis 13 Apr 11th, 2003 07:40 AM
Starting problems devschow B11/B12/KN13 82-90 chassis 6 Apr 2nd, 2003 12:08 PM
