Old Dec 17th, 2006, 11:13 PM   #1 (permalink)
the_thom
Send a message via ICQ to the_thom Send a message via AIM to the_thom
rear drum brakes to disk
Does anybody know how difficult this conversion would be? I figured I'd have to find a rear SE-R axle from a junk yard.
the_thom is offline   Reply With Quote
Old Dec 17th, 2006, 11:42 PM   #2 (permalink)
l.a.x.i.r.
l.a.x.i.r.'s Avatar
Send a message via AIM to l.a.x.i.r. Send a message via Yahoo to l.a.x.i.r.
try this out Fastbrakes.com
98 gxe, weapon R sercret weapon intake w/ram air kit, speed chip, 10.3mm plugwires, pacesetter headers, 2.5inch exhuast, 4inch Hayame XTR muffler. http://www.cardomain.com/id/laxir
l.a.x.i.r. is offline   Reply With Quote
Old Dec 18th, 2006, 01:40 AM   #3 (permalink)
Katana200sx
P.O.S. Truckdriver
Katana200sx's Avatar
Send a message via ICQ to Katana200sx Send a message via AIM to Katana200sx
you can go the fastbrakes route and save alot of labor and sourcing, or go your way and get a se-r axle and hardware.
Katana200sx is offline   Reply With Quote
Old Dec 18th, 2006, 01:47 AM   #4 (permalink)
ilikespeeding
Why would you need an axle on a front drive car to do a rear brake swap?
1990 Eclipse GSX - Money Eater
1996 Eagle Talon TSi - Wrong wheel drive
1996 Sentra GXE - Daily Driver
ilikespeeding is offline   Reply With Quote
Old Dec 18th, 2006, 08:35 AM   #5 (permalink)
the_thom
the SE-R has disk brakes in the rear, I have a GXE which has drum breaks. I figured the axle would be different.
Old Dec 18th, 2006, 08:37 AM   #6 (permalink)
the_thom
actually fastbrakes looks like it's fairly simple.
Fastbrakes.com
thanks for the help
- thom
Old Dec 18th, 2006, 12:55 PM   #7 (permalink)
ilikespeeding
What does that have to do with an axle? The rear, unless linked by a solid rear bar, which I'd struggle to call an axle, wouldnt have an axle unless it's rear drive. Obviously, nissan sentras are not rear wheel drive machines.
Old Dec 18th, 2006, 02:30 PM   #8 (permalink)
Katana200sx
P.O.S. Truckdriver
b/c we have called it a freakin rear axle since i've been on this forum. even when we talk about wheels at work we call them axles for the ones that don't have power and the ones that do we call drive axles
Old Dec 18th, 2006, 10:44 PM   #9 (permalink)
IanH
Post Freak
IanH's Avatar
Yes, a beam axle.
I looked at doing this by replacing the axle and found that a lot of wrecking yards sell the axle minus the disc brakes, making the whole thing much more expensive.
I finally found an axle complete in OK for $150 but without hand brake ( e- brake) cables.
Wimped out and brought the fast brakes set up from a forum member complete off a wrecked car.
1997 Sentra GXE .... SOLD
1997 S-ER 5 sp yea !!!
2003 Pathfinder SE 4WD
IanH is offline   Reply With Quote
Old Dec 19th, 2006, 11:35 PM   #10 (permalink)
ilikespeeding
Originally Posted by IanH
Yes, a beam axle.
Yea, I took a look under my car while on a lift today at work and I see what you're talking about. Looks like nissan designers took a trip the the garbage can and picked that up and walked it over to manufacturing for casting. Honestly, it looks like that 'axle' took about a good 30...maybe 40 seconds to design.
Old Dec 20th, 2006, 02:24 AM   #11 (permalink)
Katana200sx
P.O.S. Truckdriver
that piece of garbage you are referring to handles as well as the independant rear of the b13 though. don't know if that speaks to the good design of the multi link beam or what
Old Dec 20th, 2006, 01:55 PM   #12 (permalink)
the_thom
its simple but it does well for what it is
Question about rear brakes on Sentras Red Lion Suspension & Brakes 9 Aug 16th, 2006 05:08 PM
replacing rear drum brakes sentraspecialist B15 2000-2006 7 Jul 21st, 2006 12:34 PM
Locking up the rear brakes . . . thestunts200sx Suspension & Brakes 8 Jan 1st, 2006 08:58 PM
Installing rear disc brakes on NX1600 1993NX1600canadian B13 91-94 chassis 5 Dec 15th, 2003 05:22 PM
::HOW TO:: change rear drum brakes! holy200sx B14 95-99 chassis 4 May 19th, 2003 10:28 AM
