Old Nov 29th, 2006, 05:47 PM   #1 (permalink)
WhatDah
Check engine light
Today i went to the mechanic shop because my Check egine light has been on for a while. However, The guy at the shop told me that it is complicated to run a test on an old 95 nissian 200 sx. He didn't know how to do it. Is it really that hard? he also said all the yr 96 below cars have "OBD I" with many different plugs to run a test on it.
Can someone give me some suggestions? Should i take it back to the dealer and have them check it out and i know it 's going to be expensive if i take it back to the dealer.
thanks
WhatDah is offline   Reply With Quote
Old Nov 29th, 2006, 09:50 PM   #2 (permalink)
RedHead7
RedHead7's Avatar
The next thing I would do is take it to the dealer, but you could also pull the ecu codes yourself. There is a sticky on this forum (the B-14 one) that says how to do this, but if you do not want to do it, you will have to take it to the dealer. And by the way, yes our '95s have OBD I, which is hard to test. OBD II is easier to test, you just plug up a cable to your car and it tells you what is wrong and how to fix it, too bad we don't have that.
Minor Modifications To My Car: Razo Shift Knob, Eibach Sportline Springs, KYB AGX Shocks, SS AutoChrome Header, Custom Cat-back, Injen CAI, B&M Short Shifter -- More to come soon!
RedHead7 is offline   Reply With Quote
Old Nov 29th, 2006, 09:51 PM   #3 (permalink)
azkicker0027
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
pre OBD2 cars have their own manufacturer specific data link connectors. the dealer may be the only option, unless you get to the ECM and manually get the flash codes. the procedure should be lurking around here somewhere.
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://www.200sxonline.com/community/
azkicker0027 is offline   Reply With Quote
Old Nov 30th, 2006, 12:26 AM   #4 (permalink)
WhatDah
thanks for the replies. I found this site from the forum. 1996 Nissan 200SX computer codes
is this the right way to do it on a OBD I?
Old Nov 30th, 2006, 12:42 AM   #5 (permalink)
Burn 17
Nissan Fanatic
Burn 17's Avatar
Send a message via MSN to Burn 17
ya know i would bet a place like autozone would have the corredct software, all it is, is a scanner like the obd2 but has a plug that is car specific,(the dealer may be the only one to have this plug) and the "key" uploads info into the obd scanner
NEW!!1987 300ZX
200 sx auto cross beast--
Intake, Front and Rear Strut bars, Major exhaust leak.98style tail lights, clear corners, and halo angle eyes, Hot Shot headers/Downpipe(still need money for the rest of it)
Mazda B2200 Mini Truck
Burn 17 is offline   Reply With Quote
Old Nov 30th, 2006, 08:24 AM   #6 (permalink)
nova73guy
Nissan Addict
nova73guy's Avatar
Send a message via AIM to nova73guy Send a message via Yahoo to nova73guy
'96 is OBDII, so I'd say the procedure likely won't work for your car. Check with autozone to see if they can scan it. And the guy who said it's too difficult is an idiot. Even if there are multiple connectors, it shouldn't take more than 10 minutes to get the codes.
Get plastic surgery, there ain't no maybe. Your ugly face still ends up on your baby.
nova73guy is offline   Reply With Quote
Old Nov 30th, 2006, 09:42 PM   #7 (permalink)
captain_shrapnel
Atheist Libertarian
captain_shrapnel's Avatar
My local autozone couldn't pull obd 1 codes, but for $20 pep boys could. I got the diagnostic code and found out my issue was egr. And if your mechanic can't figure it out you should think about a new one.
Stillen intake, HSS Headers, JWT flywheel/clutch, JWT ecu, ST swaybars, Stillen STB, AD22VF, JWT mounts, B+M sts, Walbro fuel pump, Koyo, S4's waiting for install
captain_shrapnel is offline   Reply With Quote
Old Nov 30th, 2006, 11:06 PM   #8 (permalink)
WhatDah
thanks, i just saw a sticky post, "How to manually pull and define ecu error codes" by Nostrodomas. is it easy to take the computer out and pull the codes by myself? It doesn't look like there is a lot of space to pull the computer out in my car or do i have to take out the stick shift?
Old Dec 1st, 2006, 11:54 AM   #9 (permalink)
captain_shrapnel
Atheist Libertarian
Its easy to do. Don't do it if you have a JWT ecu though, the diag screw is missing. JWT removes it to keep people from tampering with the ecu (my situation!). Found this out the hard way, after I pulled it out. And no, you don't have take the stick out.
Charging System FAQs blackmaxima88 B13 91-94 chassis 2 May 5th, 2008 01:13 AM
'96 Altima w/97 engine Check Engine Light alexaltima U13 1993-1997 Altima 0 Nov 24th, 2005 10:02 AM
'96 Altima w/97 engine Check Engine Light alexaltima U13 1993-1997 Altima 0 Nov 24th, 2005 10:00 AM
Check Engine Light stays on...guess why zlady Z31 300ZX(T) 11 Oct 8th, 2004 08:32 AM
check engine light & emissions nismofreak GA16DE 1.6L Engine 5 Jan 21st, 2003 11:15 PM
