Old Nov 20th, 2006, 07:11 PM   #1 (permalink)
WhatDah
Clutch Problem?
when the car is turned off, I can hear the squeaking noise as i shift gears. Also when I try to enter the corner with high speed, I have a bit of a hard time to shift down to 2nd gear and make the turn. The stick shift's sticks a little bit when I try to downshift to 2nd gear. (like when you try to beat the yellow light and make a left turn, your engin will rev to like 5-6rpm, and you shift to 2nd gear to slow down the car and make the fast turn?)
Does that mean I need a new clutch? or is it ok to keep driving like this? my car is 95 200sex 1.6L with 107k mile
thanks
WhatDah is offline   Reply With Quote
Old Nov 22nd, 2006, 03:18 PM   #2 (permalink)
Burn 17
Nissan Fanatic
Burn 17's Avatar
Send a message via MSN to Burn 17
ok what the squesking is is probably just a lack of wd40, as for shifting down are you just trying to down shift, or are you double clutching and matching rpms, if your not it may make it hard to shift down,
NEW!!1987 300ZX
200 sx auto cross beast--
Intake, Front and Rear Strut bars, Major exhaust leak.98style tail lights, clear corners, and halo angle eyes, Hot Shot headers/Downpipe(still need money for the rest of it)
Mazda B2200 Mini Truck
Burn 17 is offline   Reply With Quote
Old Nov 22nd, 2006, 09:19 PM   #3 (permalink)
WhatDah
thanks for replying. The Squeaking is coming form the bottom of the car when it is off. And where should I aplly Wd40 on? Also, I trying to down shift to 2nd gear to slow down the car to make the turn in fairly high speed.
oh and is it true that it's time to replace your clutch at 100k mile?
Old Dec 26th, 2006, 04:47 PM   #4 (permalink)
SupraMK3
SupraMK3's Avatar
Your clutch is probably running low. If you drive it hard then your clutch only last about 50K before you notice hard shifting or slipping. I just flushed tranny fluid and change clutch this weekend. Now my clutch shift so smooth and no more slipping. My car only had 94K miles on it and the lube on my clutch throwout bearing was gone. This will also cause hard shifting.
1989 Supra Turbo
http://images5.theimagehosting.com/k.44.jpg
SupraMK3 is offline   Reply With Quote
Old Jan 2nd, 2007, 09:46 PM   #5 (permalink)
Divo25
Gig 'Em Aggies !!
Divo25's Avatar
Send a message via AIM to Divo25
I drive a 97 sentra 5 speed as well and i had the same problem with 2nd ... if you hold the clutch down all the way down and then keep the stick positioned to second gear it will eventually shift into second gear... you just have to keep the stick there a while if it doest shift at first try
Divo25 is online now   Reply With Quote
Old Jan 5th, 2007, 11:01 PM   #6 (permalink)
Burn 17
Nissan Fanatic
Burn 17's Avatar
try to get your rpms up there with the car in nutral befor you bring it into 2nd gear, this shoiuld make your shift very smoth
NEW!!1987 300ZX
Clutch problem with 97 pickup tazor Frontier 4 Jul 5th, 2006 07:25 PM
1993 Nissan NX 2000, Clutch problem mcs B13 91-94 chassis 2 Jun 30th, 2006 05:31 PM
2005 Clutch Problem inyourface1650 Frontier 23 Jan 17th, 2006 03:34 PM
1998 200 SX SE-R Clutch Problem Seanroy B14 95-99 chassis 3 Nov 4th, 2005 11:00 AM
Maxima Clutch fade problem...again ( Long) terrys A34 2004-2008 7 Sep 1st, 2005 11:16 PM
