» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Old Nov 1st, 2006, 12:47 AM   #1 (permalink)
sid443
Tail Light Problem
I have a strange problem with the tail lights on my 1997 Sentra.
With lights off and brake pedal engaged, left tail light has only one filament on (and it looks rather dim). Right tail light works ok (both filaments on).
With lights on and brake pedal not engaged, both tail lights work as they're supposed to (only one filament on). After I hit the brake, left tail light completely turns off (both filaments), while the right one has both filaments on.
I've tried switching bulbs, cleaning contacts - no luck. All fuses look good.
Please help. Thanks!!!
sid443 is offline   Reply With Quote
Old Nov 1st, 2006, 09:29 AM   #2 (permalink)
nova73guy
Nissan Addict
nova73guy's Avatar
Send a message via AIM to nova73guy Send a message via Yahoo to nova73guy
Sounds like a bad ground. Check the ground connection to the left tail light.
Get plastic surgery, there ain't no maybe. Your ugly face still ends up on your baby.
nova73guy is offline   Reply With Quote
Old Nov 1st, 2006, 11:02 AM   #3 (permalink)
IanH
I Live Here
IanH's Avatar
Yes a bad ground, also check the blub holder for corrosion.
Are you sure this isnt a Audi , had these problems with a Audi I once owned.
When one filament is on it grounds through the second filament, causing it to be dim.
When both are ON, both at 12V, and the ground is open, no current can flow so they appear both appear OFF. Exactly the problem you describe.
1997 S-ER 5 sp Rear Ended 17 Oct !!
going to be written off !!
2003 Pathfinder SE 4WD
1997 Sentra GXE .... Sold 2008
2001 Sunny N16 RHD (N16 Nissan Bluebird Sylphy) Sold
IanH is offline   Reply With Quote
Old Nov 2nd, 2006, 12:05 AM   #4 (permalink)
sid443
Thank you!!! You guys were right on the money - ground wire got disconnected, right below the bulb holder. Was easy to find once I knew where to look. Thanks again!
Quick tail light question Acceler8ter Cosmetic Mods 1 May 26th, 2005 09:49 PM
Tail Light Problem BlazinSent B14 95-99 chassis 1 Feb 8th, 2005 03:00 PM
B13 "Engine" warning light...problem? Russellc B13 91-94 chassis 8 Jul 29th, 2004 08:31 PM
Service Engine Soon light problem hamg GA16DE 1.6L Engine 7 Jul 7th, 2004 02:28 PM
head light problem... viciousxp B13 91-94 chassis 1 Jun 16th, 2004 11:29 AM
