» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Old Jun 12th, 2002, 08:43 PM   #1 (permalink)
DNE's VZR Conversion
LIUSPEED's Avatar
Send a message via AIM to LIUSPEED Send a message via MSN to LIUSPEED Send a message via Yahoo to LIUSPEED Send a message via Skype™ to LIUSPEED
Unhappy EGR Valve Problem
Does else have an EGR Valve problem like me and TeknoKid. Our EGR Valve doesnt work because of our exhaust system.
we both drive the 95-98 Nissan Sentra GXE. Has anyone have this problem before? and how did you fix it?
TeknoKid- - 96 Sentra GXE with 2 " piping
Me - - 95 Sentra GXE with 2.25 " piping.
95 Sentra GXE with Mods
LIUSPEEDTUNING.COM always remember 12/31/08 RIP
LIUSPEED is offline   Reply With Quote
Old Jun 14th, 2002, 02:25 PM   #2 (permalink)
96BlkSE-R
Guest
Posts: n/a
EGR
I dunno if it is the same problem as my 96 SE-R has, but it could be. I don't think it is your exhaust system causing it, unless you tampered with the connection at the exhaust manifold/header.
The actual EGR piping was too large at one time & Nissan redesigned it. I'm technical, but not this technical - take a look at SR20DE.net and look under the Problems section.
Hopefully the info will help. Good luck...
Old Jun 17th, 2002, 01:05 PM   #3 (permalink)
Destroyer of Engines
aminidab's Avatar
I have the same problem with my car, but it happened before I got my exhaust installed, so that didn't cause it. I haven't tried to fix it yet, but I know others have had this same problem. If you do a search at the forums at www.b15sentra.net , you should be able to find some info about fixing it.
2008 BMW 135i
96 Sentra GXE
Boost is addictive
265WHP/257WTQ
aminidab is offline   Reply With Quote
Old Jul 30th, 2002, 04:28 PM   #4 (permalink)
SE-200sx
Guest
Posts: n/a
What do you do to fix this problem because i have the same problem.
Old Jul 30th, 2002, 09:21 PM   #5 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
Post What problem?
No one has explained what the problem is. The EGR system has several parts to it. It has asensor, a valve, and several rubberfitting as well. What code are you throwing? I had an EGR code, it turned out the one of the rubber EGR hoses wore out over time, I simply took another piece of hose and replaced it. You may also want to take the fittings apart and clean it out.
Otherwise give us more as to what the problem is.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Jul 30th, 2002, 09:42 PM   #6 (permalink)
LIUSPEED's Avatar
i think mine is a valve .. they said the valve not workin
Old Jul 31st, 2002, 12:56 AM   #7 (permalink)
Boost anyone?
Teknokid's Avatar
Send a message via AIM to Teknokid Send a message via Yahoo to Teknokid
My valve is non functioning as well
Chris
My ebay listings
Tekno AutoHaus
Originally Posted by Altim8GA
Does it really matter? That car is so visibly loud, a deaf mute starts to cuss it 2 exits away.
Teknokid is offline   Reply With Quote
Old Jul 31st, 2002, 03:05 AM   #8 (permalink)
Platinum
CarbonBlack200's Avatar
Send a message via AIM to CarbonBlack200
take a valve off and test it. it's not that difficult. clean it first and try to suck it. if valve closes when you suck, that means your valve is still good. You can use the carb/throttle body cleaner to clean the valve.. maybe it just needs to be cleaned.. I know it's not your exhaust system causing that problem.
CarbonBlack200 is offline   Reply With Quote
Old Jul 31st, 2002, 09:37 AM   #9 (permalink)
in^3,N20,RPM,PSI
James's Avatar
Hey I have a spare egr valve if you guys want me to bring it on Friday... But I don't think it's your egr valve either, I'll bet money it's a hose.
Old Jul 31st, 2002, 11:55 AM   #10 (permalink)
LIUSPEED's Avatar
yes please.. and if u got the lil engine reader code thingy ma bopper bring that as well =)
Old Jul 31st, 2002, 11:58 AM   #11 (permalink)
in^3,N20,RPM,PSI
James's Avatar
I got a screw driver, socket and hammer... does that help?
Old Jul 31st, 2002, 12:00 PM   #12 (permalink)
LIUSPEED's Avatar
as long as it dont break my car.. sure .. hehe..
Old Jul 31st, 2002, 12:36 PM   #13 (permalink)
Boost anyone?
Teknokid's Avatar
Hey James i know this is off topic but you still think you can bring your timing gun and advance my timing??
Chris
My ebay listings
Tekno AutoHaus
Old Jul 31st, 2002, 01:03 PM   #14 (permalink)
in^3,N20,RPM,PSI
James's Avatar
yeah thanx for the reminder tho
Old Jul 31st, 2002, 01:08 PM   #15 (permalink)
LIUSPEED's Avatar
does n-e-eone have the check engine light code reader? if so can they bring it 2 the meet
EVAP canister vent control valve closed large168 SR-Series Engines (DE/VE) 43 Dec 31st, 2009 06:37 PM
97 Pickup EGR problem viper2 Truck & SUV 11 Aug 30th, 2003 06:27 AM
EGR Valve Problem Kambrian B14 95-99 chassis 16 Apr 25th, 2003 03:00 AM
Newb with an EGR problem... ArCerian GA16DE 1.6L Engine 8 Oct 30th, 2002 09:16 PM
EGR control valve...... qinsac SR-Series Engines (DE/VE) 6 Oct 11th, 2002 09:54 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
