Old Aug 4th, 2006, 08:24 PM   #1 (permalink)
sergod
Angry Stupid Brake Lights...!!!
my friend noticed last night that my right brake light wasnt working, so today i went and bought new bubls and when i installed it, it still wanst working. so i checked the fuse and it was ok. then i put the bulb that i thought wasnt working on the left side and it worked. since i have an after market rear lamp which included the wire assembly, i tried switching the wire assembly to rule out any problems w/ the sentras oem wirrings. so after switching the wires, the left side was the one that didn't work now and the right one worked just fine. now i know the problem is with the wire assembly but, why was the damn thing still not lighting when i step on the brake cause the parkinglihts are fine and the signal lights are fine. so i decided to just switch that small black box that is part of the after market rear light wire assembly and when i switced it, the right side didn't work again. now i know definitely what the damn problem is...what do you call that small black box, possibly fuses inside it? and i cant open that small box unless i brake it, seems to be one solid box except for the rubbery bottom were the wires come out......any comments, suggestions will be greatly appreciated......and sorry its long and not straight to the point.......thanks...........
sergod is offline   Reply With Quote
brake lights southernlatino104 General Altima/Stanza discussion 0 Aug 3rd, 2006 11:24 PM
Brake Lights won't turn off vandermast U13 1993-1997 Altima 13 Sep 10th, 2005 12:26 PM
goofy brake lights lowNslo B13 91-94 chassis 0 Nov 25th, 2004 01:38 AM
brake lights on XxREMYRxX B15 2000-2006 4 Oct 21st, 2003 04:18 PM
Charging problem: Brake & Charging lights both on tucson_b14 B14 95-99 chassis 8 Mar 28th, 2003 04:32 AM
