Running Rich/ Gas Smell - Nissan Forum
post #1 of 5 Old Jul 14th, 2006, 03:25 PM Thread Starter
I did a search and found some stuff that seemed related but I'm not sure so here's the problem I'm having.
I have a 1995 Nissan 200sx Se-R. While I was driving to the store my car started to have a severe lack in power, sputtered when I'd accelerate and eventually was jerky the whole time. I had white smoke POURING out the tailpipe all of the sudden and a strong gas smell if my car is on.
From what I read it might be the 02 sensor or temp sensor. My plugs look shot now so I'm thinking new ones of thoughs are needed too. Any idea's? Thanks in advance
1995 200sx SE-R
Spykce is offline
post #2 of 5 Old Jul 14th, 2006, 06:32 PM
Madmaxfl's Avatar
The white smoke deal is concerning, is it still smoking? ?counld be a head gasket, may have to do a compression test.
Madmaxfl is offline
post #3 of 5 Old Jul 19th, 2006, 08:41 AM Thread Starter
From what I could figure out I'm getting way to much gas(obviously). So I started with the sensors. One of my oxygen sensors was giving weird readings so I switched it with a new one. That helped somewhat but didn't fix it. Next I went with the Fuel Pressure Regulator. The car seemed to run smoother but it's still way to rich. Gas is no longer coming out the tail pipe though. It's still smoking a little. I guess it may be the injectors. Still working on fixing the problem.
1995 200sx SE-R
Spykce is offline
post #4 of 5 Old Jul 19th, 2006, 10:21 PM
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
black smoke is usually the indication of a rich mixture.
white, for coolant burning.
blue for oil consumption.
can you check the reading at the IAT and see what temp the ECU supposedly receives?
i had to put my IAT back into the air stream to correct my rich running problem.
Naturally aspirated autocross car.............naturally.
Retired STF champ car.
azkicker0027 is offline
post #5 of 5 Old Jul 20th, 2006, 01:01 AM
White smoke pouring out your exhaust means your burning coolant. You might want to look into that.
If its running super rich check your IAT,ECT,and MAF sensors. You already replaced your O2 so apprently thats not the problem. Sometimes the ECT will fail and cause the engine to think the engine is extremely cold and therefore dump fuel into the cylinders. Same with your IAT.
Your PCM may be compensating for a lean condition as well, so make sure all your vacuum lines are connected and not broken or anything like that.
**WILL WORK FOR HP**
Kennizmo is offline
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Rough idle, gas smell from the rear left - help! blackonblack J30 1989-1994 Chassis 5 Aug 4th, 2006 04:56 PM
Bad Gas smell inside '93 300ZX twin turbo RAYLEON Z32 Chassis 300ZX 6 Jun 12th, 2006 01:07 PM
Magnaflow Exhaust - Running Rich!! HELP! kabeyta General Z Discussion 1 Apr 22nd, 2005 10:31 PM
gas smell Dacypher2003 B13 91-94 chassis 3 Sep 27th, 2004 11:15 PM
Running way to Rich!! Dropped89 B11/B12/KN13 82-90 chassis 2 Jan 4th, 2003 04:02 PM
You may post new threads
You may post replies
BB code is On
