Hi, I have a 95 Nissan Sentra that I'm having problems starting. It cranks for a long time before finally starting. Once it starts, it runs fine. If I start it within a couple of hours it doesn't have any problems but if I start it after say 5-6 hours.. it cranks forever before finally starting.
I think it is due to oil leaking out of the distributor which corroded the distributor cap. My mechanic suggested getting a new distributor cap and spark plug wires to solve the problem temporarily. Does this make sense?
I was wondering if replacing the distributor O ring will fix the problem for good. The understanding I have so far is that there are two rings - one is a mounting ring that can be easily replaced and another is an 'o' ring somewhere inside the distributor which is not easy to replace. Is there a way I can fix this without buying a new distributor?
I appreciate your patience in going through this!
