Old May 15th, 2006, 03:17 PM   #1 (permalink)
wd40
wd40's Avatar
98 Sentra won't start, need help fast!
1998 Sentra 1.6 won't start, have fuel and spark, starter and fuel filter great. Makes funny sound when trying to start. Engine check light on. Ran fine yesterday, have had no problems, fuses seem ok.
My daughter needs to drive car 6 hours back to college this coming Friday. Need help fast!
wd40 is offline   Reply With Quote
Old May 15th, 2006, 04:17 PM   #2 (permalink)
davido
davido's Avatar
re
It might be the starter, My mom's sentra did the same thing. have your battery tested, if it is good then most likely the starter. what kind of sound it it, slow dragging sound ?a whirr?
davido is offline   Reply With Quote
Old May 16th, 2006, 04:37 PM   #3 (permalink)
Twiz
TwiztidKidd
Twiz's Avatar
Test each and every injector. Test to see if their resistance is within the specs. I believe it has to be in between 10 and 14 ohms. If it reads more then that injector is most likely your problem. It could be more than one injector so don't stop at the first one, test all of them. Also I'd look at the spark plugs, line up all four next to each other and compare them. Prolly its best if you pull out all four spark plugs after a few attempts to start.
Twiz is offline   Reply With Quote
Old May 16th, 2006, 06:44 PM   #4 (permalink)
Tycar
pull the engine check light code using the method described in the heading of this forum or the ga16de 1.6 forum, let us know what the computer is trying to tell you... that will help and fast.
Tycar is offline   Reply With Quote
Old May 17th, 2006, 07:24 AM   #5 (permalink)
wd40
wd40's Avatar
Car started fine this morning as we were getting ready to have it towed. Canceled the tow, checked everything, no code shows up, baffled at this point, but it is running now. Going to let daughter drive it back to school. Thanks for your help.
Old May 17th, 2006, 10:25 AM   #6 (permalink)
Burn 17
Nissan Fanatic
Burn 17's Avatar
Send a message via MSN to Burn 17
best of luck and i hope she makes it there ok, sometimes even if your battery is good, the terminals/ wires are filthy, thus causing a voltage leek and this will make the car hard to start or even run
NEW!!1987 300ZX
200 sx auto cross beast--
Intake, Front and Rear Strut bars, Major exhaust leak.98style tail lights, clear corners, and halo angle eyes, Hot Shot headers/Downpipe(still need money for the rest of it)
Mazda B2200 Mini Truck
Burn 17 is offline   Reply With Quote
Old May 18th, 2006, 07:48 AM   #7 (permalink)
wd40
wd40's Avatar
thank you so very much for your advice and help. Drove the car around yesterday, and it acted just fine. Will give daughter "emergency car repair funds", just in case. And she has a cell phone if she gets stranded. What did we do without those?
Again, thanks.
B13 Sentra E won't start :( skud_dusty B13 91-94 chassis 10 Apr 30th, 2005 05:20 AM
98 sentra se header kevdawg821029 SR-Series Engines (DE/VE) 2 Jan 11th, 2005 06:52 PM
98 Sentra jack/lift points and Rhino ramps 98Sentra5spdbas B14 95-99 chassis 1 Jul 20th, 2004 04:54 PM
98 sentra Help won't start pdaddy666 B14 95-99 chassis 1 Apr 17th, 2004 10:43 AM
