Old May 11th, 2006, 12:10 AM   #1 (permalink)
desertred
Help! Manual Tranny Kicking Out of Top Gear
Specifics: 95 200SX, approximately 200K miles, performed engine swap 15K miles ago with a new clutch.
Just started doing this today. While driving down the road, the transmission will disengage itself on a sporadic basis when in 5th gear. Usually there will be one or two quick shudders prior to disengaging. But when engaged, the engine and tranny pull strong. No problems with gears 1-4 (yet).
The car sees a lot of highway miles, so 5th gear has seen extensive use. No other symptoms or problems have shown themselves. The car runs nice and strong until it kicks out of 5th gear.
Does it sound like the transmission is going, or might there be some other problem? As noted above, a new clutch and cable was installed with an engine swap 15K miles ago. The transmission is the original unit (I bought the car new).
desertred is offline   Reply With Quote
Old May 11th, 2006, 04:33 AM   #2 (permalink)
Sethticlees
Nissan Addict
Sethticlees's Avatar
5th gear pop out, maybe?
A common problem with the early nissan transmissions.
Sethticlees is offline   Reply With Quote
Old May 11th, 2006, 09:15 AM   #3 (permalink)
oliverr87
Nissan Fanatic
Send a message via AIM to oliverr87 Send a message via MSN to oliverr87 Send a message via Yahoo to oliverr87
You have 5th gear pop out.
oliverr87 is offline   Reply With Quote
Old May 11th, 2006, 01:52 PM   #4 (permalink)
desertred
Hmmm....was not aware of this. Thanks for the replys.
A search for "5th gear pop out" didn't reveal to much, except that the problem was fairly common in the B13s and not so common among the B14s. I noticed that there is evidently a kit that could cure the problem, but as my tranny has 200K on it, I'm wondering if it might be better just to get a low mileage replacement from the yard. Anyone know what this kit does?
Are all the b14 5-speed trannys interchangebale for the 1.6L engines? Is there a particular year in which Nissan seemed to have solved the problem in the B14 transmissions?
Old May 12th, 2006, 08:34 AM   #5 (permalink)
oliverr87
Nissan Fanatic
The 5th gear pop out kit fixes the 5th gear along with the synchronizers. The original 5th gear wore down because of the way it was designed. The newer one is designed differently (and I think the material is different, if not stronger? not sure)
B14 trannys should be interchangable with the B13 ones. But there might be sensor issues I am unaware of. I think Nissan did solve the 5th gear popout problem with the B14.
Old May 18th, 2006, 12:12 PM   #6 (permalink)
Strange1
Strange1's Avatar
It sounds like your transmission is going out.I had the same problem.It started popping out my 5th gear and then it finally went out.I think you should get it checked out first to make sure.
Strange1 is offline   Reply With Quote
Manual tranny notchy/grinding blitzboi L31 2002 - 2006 8 Apr 9th, 2006 10:09 PM
x-trail auto 1st gear vs. Manual 1st gear Ampnut X-Trail 7 Feb 20th, 2006 10:24 PM
Pulsar 89 Swapping Auto Tranny To Manual Fire_Leon B11/B12/KN13 82-90 chassis 4 Sep 15th, 2004 05:00 PM
Top Gear Flying Vv Off Topic 3 Jul 23rd, 2004 07:40 PM
pops out of 2nd gear.... deez98se SR-Series Engines (DE/VE) 17 Jun 13th, 2004 08:33 PM
