Old Apr 17th, 2006, 02:21 PM   #1 (permalink)
wine
thermostat housing to water pump bolts
I managed to unbolt the water pump from the engine block. One of the bolts is sticking out from the block without a head. I've got a damaged bolt remover kit with one for 10mm (that's the size of the pump bolt).
The spot where the water pump's located is very tight (frame) and very hard to reach with the crankcase pulley and other obstacles.
After removing the top engine mounts, should I jack the engine up or down to get better access?
There are 2 bolts that go from the thermostat housing to the water pump.
I've removed one of them. But the other (in the back) is a pain in the a--
to even get a socket into. Suggestions on how to get to it?
wine is offline   Reply With Quote
1989 Maxima Water Pump Install 89Maxima89 J30 1989-1994 Chassis 8 Apr 10th, 2005 06:25 PM
Broken Belt? (Water Pump / Power Steering) jvaruzzo B14 95-99 chassis 3 Jan 4th, 2005 04:56 PM
Which bolts move PS pump? OmarMiPi GA16DE 1.6L Engine 5 Feb 25th, 2003 12:48 PM
Water Pump Woes... GA16DESentraXE B13 91-94 chassis 6 Dec 17th, 2002 01:41 PM
