» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Old Jun 11th, 2002, 12:52 PM   #1 (permalink)
Banned
Niss200SXGTR's Avatar
Send a message via AIM to Niss200SXGTR Send a message via Yahoo to Niss200SXGTR
Cross drilled rotors.. and brake pads......
I am going to be buying some cross drilled rotors, and preformance brake pads.. can i use the stock calipers? or do they need to be replaced too.. because my stock brakes are now "to the squeeling" point. which is where the pads are so low, that it makes a constant noise..
Niss200SXGTR is offline   Reply With Quote
Old Jun 11th, 2002, 01:35 PM   #2 (permalink)
Re: Cross drilled rotors.. and brake pads......
I'd recommend against cross drilled rotors unless you are just buying them for the look. Stock sized cross drilled rotors are more prone to cracking. Slotted rotors would be better, but I think good quality stock rotors work well with a good pad. I like the Axxis Metal Masters, they also have a more aggressive pad called the Metal Master Ultimates which are Euro spec Metal Masters basically.
I'm not sure if you have a SE-R or not so I'm not sure if the Ultimates are available or not for you. You can get them for the SE-R but I'm not sure about the non-SE-R cars.
The other option would be to buy some NX2000 rotors and loaded calipers (you need the ones that come with the mounting plate). I think this would be a better upgrade if you don't have them already.
Ryan Besterwitch
NissanPerformanceMag.com
95 200SX SE-R Turbo - 392hp 367ft-lbs @ the wheels
93 NX2000
2002 Subaru WRX Wagon
Boosterwitch is offline   Reply With Quote
Old Jun 11th, 2002, 02:00 PM   #3 (permalink)
Banned
i see
Well, if the cross drilled rotors blow nuts.. the stock ones will do the same? i thought the cross drilled rotors were supposed to be like.. god!
Old Jun 11th, 2002, 02:55 PM   #4 (permalink)
Driver
Send a message via AIM to barnoun
I agree with Booster. The drilled rotors tend to crack more since they've been weakened with the drilling of the holes. If you drive slow you don't have to worry about it, but why'd you get better brakes if you're going to drive slow in the first place.
barnoun is offline   Reply With Quote
Old Jun 12th, 2002, 01:29 AM   #5 (permalink)
Cross drilled rotors are an old school relic. Apparently, old brake pads use to produce lots of gas; this would cause the pads to float on the rotors instead of grabbing them which lead to no braking. So they put in the holes so the gases could escape. That's not a concern anymore really today. By drilling holes in the rotors, you introduce high stress points which leads to them cracking. Good x-drilled rotors will have chamfers which will help relieve the stress but they will eventually still crack. Even the factory Porshce x-drilled rotors crack all the time; makes me wonder why they still use them. Basically, go look at any real race car (F1, CART, IRL, Touring cars, WRC rally cars, NASCAR even) and they all use either solid or slotted rotors. That's what I've heard anywayz...
Khiem
spdracerUT is offline   Reply With Quote
Old Jul 3rd, 2002, 09:41 PM   #6 (permalink)
Nissan Fanatic
Send a message via AIM to omega
i think i saw someone post about how they choose to use slotted rotors, well yea technically slotted rotors are great, for racing, they resurface your pads every time the pads pass by the slots to prevent glazing in high temp situations like racing where you replace the pads every race anyway, if your a street driver, stay away, and i'm not an expect on cross drilled but as I understand it, it helps to dispurse heat better, the cooler you keep your brakes the better the grip so to speak between your pads and rotors reducing stopping times, so it sounds like a good idea to me
omega is offline   Reply With Quote
Old Jul 3rd, 2002, 09:55 PM   #7 (permalink)
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
brakes....
also check out project 1.6 on sport compact car for their 200, they did an upgrade using ye olde nissan factory parts, and some very nice steel-braided brake lines and motul brake fluid, check it out..... it's going to provide a very good insight.........
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://shop.3bspecialties.com/main.sc
azkicker0027 is offline   Reply With Quote
Old Jul 3rd, 2002, 10:52 PM   #8 (permalink)
Its a JEEP thing...
Black200SXSER's Avatar
this was KILLED on Altimas.net....
If you really want to know what works...read ALL 44 pages...
http://www.altimas.net/forum/showthr...slotted+rotors
there is some BS in there.so wade thru it...
Brad B. '01 Solar Yellow Frontier CC
'96 Superblack 200SX SE-R (SOLD)
Black200SXSER is offline   Reply With Quote
Axxis Ultimate brake pads dono200sx Suspension & Brakes 8 Nov 24th, 2003 04:45 PM
brake rotors? 98se-rNOS Suspension & Brakes 18 Sep 19th, 2003 12:17 PM
new rotors and pads, brakes smoking now pearsont74 Suspension & Brakes 5 Jul 28th, 2003 09:43 PM
KVR Slotted or Cross Drilled Rotors? SentraBoy Suspension & Brakes 6 Oct 23rd, 2002 09:21 PM
i need sloted brake rotors? lowryder407 B13 91-94 chassis 7 Aug 15th, 2002 02:39 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
