Old Mar 11th, 2006, 03:57 AM   #1 (permalink)
b14sentra
help on Oil change
i have 96 sentra 1.6 with 122.XXX mile on it. what oil should i use?
b14sentra is offline   Reply With Quote
Old Mar 11th, 2006, 04:29 AM   #2 (permalink)
ghost_ryder35
Send a message via Yahoo to ghost_ryder35
5w 30 or 10w 30
Originally Posted by oliverr87
yea!!! my spec-v has vtec i can hear it at 6000 RPMS!!!! its so cool!!!
ghost_ryder35 is offline   Reply With Quote
Old Mar 11th, 2006, 06:06 AM   #3 (permalink)
FatBoy4
Pimpin the BigDaddyMobile
FatBoy4's Avatar
Send a message via ICQ to FatBoy4 Send a message via AIM to FatBoy4 Send a message via Yahoo to FatBoy4
i use castrol syntec 10w30
i got almost 160k miles
O.N.E
Oklahoma Nissan Enthusiasts
FatBoy4 is offline   Reply With Quote
Old Mar 11th, 2006, 12:07 PM   #4 (permalink)
98Midnight
Mobil 1 5w-30 is tough to beat.
98Midnight is offline   Reply With Quote
Old Mar 11th, 2006, 05:55 PM   #5 (permalink)
nissan98
nissan98's Avatar
yes,mobil 1 5w-30 is a die hard
:hal:
nissan98 is offline   Reply With Quote
Old Mar 13th, 2006, 02:03 PM   #6 (permalink)
surferboi_hco
surferboi_hco's Avatar
eh im expensive when it comes to an oil change i get this stuff from europe and it is amazing but it makes moths suddenly spawn in your wallet... if u get my drift but this oil that i get is a full synthetic that is better than mobile one and i go about 7k before i change the oil and when it comes out its not really that dirty but its like around 7 bucks a quart almost if not more
so it will rape u in the ass if u hav no money caz really ur not supposed to go from synthetic to regular oil caz that will f up ur engine it happened to a buddy of mine
~Brian
surferboi_hco is offline   Reply With Quote
Old Mar 14th, 2006, 10:58 AM   #7 (permalink)
infazorak
infazorak's Avatar
Send a message via AIM to infazorak Send a message via Yahoo to infazorak
5W-30? I've been using Mobil 1 10W-30 on my 115k GA16 Sentra because the climate here in GA rarely ever drops below zero.
Yeah, I'm a car noob. But if you want a PC rebuilt, or a Colt .45 tuned, I'm your guy.
infazorak is offline   Reply With Quote
Old Mar 14th, 2006, 11:44 AM   #8 (permalink)
dappa1
Send a message via AIM to dappa1
honestly these motors do not ned a full synthetic oil. i use the gtx high millage 10-30 in my g/f gxe sentra and the motor loves it. smooth and quiet as ever.
dappa1 is offline   Reply With Quote
Old Mar 14th, 2006, 04:46 PM   #9 (permalink)
NismoGa16
Send a message via Yahoo to NismoGa16
you need to be careful about switching a high mileage car over to synthetic oil, it's very common for all kinds of mysterious leaks to develope if the engine hasn't been very well taken care of. If you do switch to full synthetic you need to let the regular oil drain until no more will drip out. take off the oil filler cap, remove the drain plug, go inside and eat a sandwich, take a nap, go check the car, if it's still dripping, even just a little bit, go back inside and fart around on the computer for a few hours. Once ALL of the regular oil has drained out, then you can put in the synthetic, the two will not mix.
Not all who Wander are lost
NismoGa16 is offline   Reply With Quote
Old Mar 14th, 2006, 06:25 PM   #10 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
In my experience with quite a few different cars this has NEVER been an issue. The two oils will mix just fine and as long as the engine has been maintained leaks should not just suddenly develop. It is not as if you are switching to water here....
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Mar 15th, 2006, 02:07 AM   #11 (permalink)
Kennizmo
Synthetic oil is made of the same stuff as regular oil. Why wouldnt they mix?
They're different at a molecular level. Picture two surfaces rubbing together with ball bearings in between them, that would be synthetic. Now picture it with gravel, which would be normal oil.
Crude (no pun intended,ahaha) interpretation, but it works.
**WILL WORK FOR HP**
Kennizmo is offline   Reply With Quote
Old Mar 18th, 2006, 08:19 PM   #12 (permalink)
Madmaxfl
Madmaxfl's Avatar
The problem comes with the synthitic beinga cleaner oil and will clean the inside of the engine. sometimes there is a bunch or build up around seals and the synthetic will disolve this and then an old seal may leak.
Hey if you like synthetic then use it. i run it in my 1985 300 zx that has 57,000 miles and have not had a problem.
I am using Valvoline Max Life in my daughters 99 Sentra. It uses oil and I am going to replace the retangular gasket under the valve cover this week as talked about on other posts.
Madmaxfl is offline   Reply With Quote
Old Mar 18th, 2006, 09:54 PM   #13 (permalink)
WoLfFaNgZ
diesel what??
WoLfFaNgZ's Avatar
Send a message via AIM to WoLfFaNgZ
my b11 had 129,800 miles on it when i switched to synthetic 135,900 miles as of now.No leaks at all 6100 miles later
WoLfFaNgZ is offline   Reply With Quote
Old Mar 19th, 2006, 12:40 AM   #14 (permalink)
chris859
Just another nissan fan!
Send a message via Yahoo to chris859
I can't say anything about my 200sx's engine(as it only has like 40k miles on it - obviously no leaks), but I switched my Cougar over to synthetic when it had 158k miles, it now has 198k miles and is still running strong with no leaks! It has already been said, but yes synthetic and standard oils can be mixed...oil companies do it all the time - what do you think a synthetic-blend oil is made out of? Synthetic and.....? lol
chris859 is offline   Reply With Quote
Best Engine Oil???? MCHNHED B14 95-99 chassis 70 May 15th, 2008 05:21 PM
ask for help on transmission oil and steering oil change xbhong B14 95-99 chassis 1 Sep 15th, 2005 01:29 PM
Oil type and change intervals for turbo velardejose Forced Induction & Nitrous Oxide 5 Jul 18th, 2005 10:12 PM
2005 Pathy Oil Change undallas Truck & SUV 7 Apr 26th, 2005 06:54 AM
Oil change interval altima96gxe U13 1993-1997 Altima 6 Aug 28th, 2004 06:20 PM
