Old Mar 4th, 2006, 06:41 PM   #1 (permalink)
h8stoplights
power locks
my power locks have never worked(since i have had the car), i do have an alarm system installed. ive looked for the fuse, and i cant find it. ive searched the forums and i cant find any info on the kind of problem. my power windows work... someone give me some tricks to try out.
Different problem,
The whole, im not kidding.. the whole rear of my car is covered in carbon and gas mileage is sucking like 25 mpg after fuel filter, spark plugs, wires dis cap ign rotor. im takin the bosch plats out and going with the ngk non plat to see if this helps but its running rich as doo doo.
thx
h8stoplights is offline   Reply With Quote
Old Mar 4th, 2006, 07:56 PM   #2 (permalink)
ghost_ryder35
Send a message via Yahoo to ghost_ryder35
-bad sensor, possibly oxygen (theres two of them), and the PCV valve that could be culprits here for the carbon.
-And about the power locks. Its prob a blow fuse, and there is a fuse for it inside the car under the dash.
Originally Posted by oliverr87
yea!!! my spec-v has vtec i can hear it at 6000 RPMS!!!! its so cool!!!
ghost_ryder35 is offline   Reply With Quote
Old Mar 6th, 2006, 01:39 AM   #3 (permalink)
h8stoplights
I just checked all of the fuses and none are blown, im very confused about this. crazy
Old Mar 6th, 2006, 04:54 AM   #4 (permalink)
dappa1
Send a message via AIM to dappa1
take out the driver door power buttons and clean contacts with wd-40
dappa1 is offline   Reply With Quote
Old Mar 6th, 2006, 08:51 AM   #5 (permalink)
ghost_ryder35
i have to go with dappa too. if what he said doesnt work then maybe the motors for your locks died. but i highly doubt all the motors would die at the same time. Maybe its a bad ground wire for the lock system. Lock system could not be getting power. Take a test light and check the power wire going to the lock button and unlock button and test to see if you are getting power. follow the wires and make sure they are not frayed or cut in any place especially inbetween the door (the rubber booty that holds all the wires)
Old Mar 6th, 2006, 12:08 PM   #6 (permalink)
chris859
Just another nissan fan!
Send a message via Yahoo to chris859
Since when do we clean electrical parts with oil? Use either brake-clean, or electrical contact cleaner.
chris859 is offline   Reply With Quote
Old Mar 6th, 2006, 12:33 PM   #7 (permalink)
dappa1
wd-40 is not oil. i had this same problem and that worked.. wd-so is ur tool boxes best friend
Old Mar 6th, 2006, 10:51 PM   #8 (permalink)
ghost_ryder35
he's got a point, its not oil, its a penetrating lubricant
Old Mar 7th, 2006, 02:37 AM   #9 (permalink)
chris859
Yes, it is in fact a light oil(as are kerosene, diesel fuel, and a ton of other things you might not consider oil) - wd-40 is composed of %50 Aliphatic Petroleum Distilates, %25 Petroleum Base oil, and %18 Lvp hydrocarbon fluid, and the rest is carbon dioxide propellant along with other non-toxic ingredients. These contents and amounts are correct - they were taken directly from the msds for wd-40 in a spray can(the most common type). Wd-40 is a penetrating lubricant, it is also a water displacer(what it was initially developed for, hence its name - water displacer 40). I do use wd-40 as well, for lubricating parts, preventing corrosion on bare engine blocks, crankshafts, cams, etc...I just don't recommend using it on electrical parts - but feel free to do what you want. Just my .02
Old Mar 7th, 2006, 01:23 PM   #10 (permalink)
Kennizmo
My locks dont work either. They used to lock but not unlock. Then I got water in one of them now they dont do anything.
Went through wiring diagrams and tested a bunch of crap and it turned out to be the body control module. Which is expensive. So yeah, I use my hand to operate them now.
That was before the water though.
**WILL WORK FOR HP**
Kennizmo is offline   Reply With Quote
Old Mar 10th, 2006, 03:05 AM   #11 (permalink)
dappa1
ok sir, thanks for the education. i dunno whats in it or do i really care, but i kno it works. brake cleaner should do the job as well.
Old Mar 12th, 2006, 01:46 AM   #12 (permalink)
davido
davido's Avatar
re
you might try this, go to a salvage yard and see if they will let you try a new master control to see if it is the control or something else, if it is the control then you can get a new one, I got one at the dealer for 70.00, you might check e-bay also. I have my old one if you can't find one to test it on.
davido is offline   Reply With Quote
Car not starting / Power locks, parking lights not working amitverma0101 General Altima/Stanza discussion 3 Feb 18th, 2005 11:25 AM
Intermittent Power Locks cpk Truck & SUV 5 Jan 26th, 2005 01:00 PM
Substantial power gains with SR20 NA tuning morepower2 Naturally Aspirated 22 Oct 13th, 2004 03:16 PM
Power locks insanestvtop B13 91-94 chassis 8 Jul 10th, 2003 02:23 PM
1998 GXE - Power Door Locks... gpjones L30 1998-2001 Altima 1 Sep 12th, 2002 09:26 PM
