motor vibra execivamente - Nissan Forum
post #1 of 12 Old Feb 23rd, 2006, 02:09 PM Thread Starter
Exclamation motor vibra execivamente
hola soy de venezuela tengo un problema con mi sentra el motor esta muy inestable y tiembla mucho a bajas revoluciones y en minimo el motor vibra excesivamente que puede ser gracias..
HELLO
hertex is offline
post #2 of 12 Old Feb 23rd, 2006, 02:10 PM Thread Starter
por cierto es un sentra modelo b14 1998 modelo mexicano motor 1.6 L
HELLO
hertex is offline
post #3 of 12 Old Feb 23rd, 2006, 03:08 PM
Send a message via Yahoo to Brokeser
I gonna attempt to translate. I'm hispanic but my written and verbal spanish sucks. I speak spanglish
"I have a '98 B14 1.6L, Mexican model. My motor feels unstable (hunting idle?). It shakes excessively in the lower rpm's. Can anyone help me with this problem?"
I hope this helps.
L
Brokeser is offline
post #4 of 12 Old Feb 23rd, 2006, 03:09 PM
Proud 2004 X-Trail Owner
manuelga's Avatar
Ve mi firma
manuelga is offline
post #5 of 12 Old Feb 23rd, 2006, 11:00 PM
Probablemente puede ser el conector del MAF, liampa a el... tambien limpia el IAC. Si el vehiculo tiene 7 o mas años, posiblamente los montajes del motor son mal.
Novelist is offline
post #6 of 12 Old Mar 2nd, 2006, 10:41 AM Thread Starter
ya revise el conector del MAF y limpie la ICV pero la falla persiste, la vibracion se produce cuando el vehiculo desacelera es una vibracion muy fuerte pareciera problemas de la caja con respecto a los soportes de la caja y motor tengo que revizarlos ya lo habia pensado gracias
HELLO
hertex is offline
post #7 of 12 Old Mar 2nd, 2006, 04:35 PM
Send a message via Yahoo to ghost_ryder35
shit I want to contribute to this thread too. I will try my best. hablo por favor. i have no idea what I just said but I think its spanish. The vibrating motor might be due to the low rpms, bad motor mount(s), car could need a tuneup very badly.
Originally Posted by oliverr87
yea!!! my spec-v has vtec i can hear it at 6000 RPMS!!!! its so cool!!!
ghost_ryder35 is offline
post #8 of 12 Old Mar 3rd, 2006, 04:37 AM
Strange1's Avatar
Si yo tambien pienso que son los soportes del motor hay cuatro.Ya han de estar rotos.Yo tambien tengo un B-14 y tuve el mismo problema.
My SE-R
Strange1 is offline
post #9 of 12 Old Mar 3rd, 2006, 02:55 PM Thread Starter
4 soportes ? me puedes informar donde estan ubicados solo conozco dos uno para el motor cerca de la caja de relays y otro para la caja justamente debajo del acumulador o la bateria
HELLO
hertex is offline
post #10 of 12 Old Mar 4th, 2006, 02:51 PM
definitivamente los cargadores de motor vos, mira hay uno cerca de la caja, otro que esta enfrente de la caja, otro esta por donde esta el aire esos he visto yo, pero definitivamente son esos
fifo is offline
post #11 of 12 Old Mar 6th, 2006, 11:03 PM Thread Starter
eso es correcto ya consegui el soporte dañado es el de la caja esta partido gracias
HELLO
hertex is offline
post #12 of 12 Old Mar 7th, 2006, 04:16 AM Thread Starter
por cierto esta vibracion creo que la esta causando la caja tengo un problema y no se que pueda ser la caja me esta dezlisando y la reversa solo la agarra cuando acelero el motor a altas revoluciones ya le cambie el aceite y nada intente agregandole aditivos al aceite y mejoro pero ahora vibra excesivamente que puede ser el problema de la caja? me han comentado que quiza sea la valbula solenoide
HELLO
hertex is offline
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Gear in this thread - nissan Motor by PriceGrabber.com
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
