shifter bushing set need help FAST!!
I ordered the 7.1109g bushing set from energy suspension but they also have the 7.1109r bushing set and i need the bushing that is above the heat shield the long rubber one.In the 7.1109g bushing set i got two round bushings which is clearly the bushing i don't need.Does the 7.1109r bushing set come with the long rubber bushing with the hole in the middle of it that goes above the heat shield?I need help fast my OEM mount has fallen apart and my shift linkage is banging my heat shield.Thanks
