Old Feb 8th, 2006, 08:53 PM   #1 (permalink)
deadlyrays
Send a message via AIM to deadlyrays Send a message via MSN to deadlyrays
Intake Problem
got a SRI off ebay but it dun got an o2 sencor hole to put it in does anyone have one of these?
deadlyrays is offline   Reply With Quote
Old Feb 8th, 2006, 09:56 PM   #2 (permalink)
Nostrodomas
Im out of here!!!!!!!!!!
Your o2 sensor is not in your intake. I am assuming that you are talking about the intake air temp sensor (IAT).
You can do two things. Extend the wires of the IAT sensor and drill a hole into your new intake (I am assuming its a WAI) and use a rubber grommet and put the sensor in the new hole.
Or
Just stick the sensor back down the hole in the fender where the silencer is. Just make sure its around the intake so it can get an accurate temperature reading.
Nostrodomas is offline   Reply With Quote
Old Feb 9th, 2006, 01:28 AM   #3 (permalink)
unkowwn2
Or
or you can let it dangle behind the battery and close to the intake, you can also unplug the sensor, although your cpu might not read correctly, but the car will still run, never ran the car long w/o it, so i dont know how much of a change it will be.
unkowwn2 is offline   Reply With Quote
Old Feb 9th, 2006, 11:04 AM   #4 (permalink)
deadlyrays
i understand putting it near the air filter, but can someone draw me a diagram of how lol
Old Feb 10th, 2006, 06:34 PM   #5 (permalink)
invisble1
I also bought an Intake and when I went to install it, I noticed that none of the hoses that came with the intake doesn't fit my car.
I bought one of the cheap ones on Ebay, but I'm going to get a much better air filter.
Any help would be appreciated.
Thx
invisble1 is offline   Reply With Quote
Old Feb 13th, 2006, 02:41 PM   #6 (permalink)
Burn 17
Nissan Fanatic
Burn 17's Avatar
Send a message via MSN to Burn 17
when i did that i had my sensor sitting close to my intake and the car ran fine i ran it like that for maby three months untill i purchaesed a new car, but the sensor is there for a reson....
NEW!!1987 300ZX
200 sx auto cross beast--
Intake, Front and Rear Strut bars, Major exhaust leak.98style tail lights, clear corners, and halo angle eyes, Hot Shot headers/Downpipe(still need money for the rest of it)
Mazda B2200 Mini Truck
Burn 17 is offline   Reply With Quote
Old Feb 13th, 2006, 11:48 PM   #7 (permalink)
unkowwn2
if the hoses dont fit you can go to checkers or napa auto parts and buy intake tubing for like a dollar a foot, which isnt so bad, usually in black. if your really conserned about the sensor issue i suggest you get a drill and under the cone filter there should be a rubber part, drill carefully through and stick the sensor in there, and use a glue gun so it wont pop out. a fast solution to your problem.
Faq About Sr20ve LIUSPEED SR-Series Engines (DE/VE) 34 Feb 14th, 2008 01:21 PM
This is for the Tech Heads El Fuego U13 1993-1997 Altima 9 Nov 1st, 2007 06:24 PM
96 Altima head gasket/head/heat damage problem? 96AltimaOwner U13 1993-1997 Altima 0 Aug 20th, 2004 08:58 AM
problem with my air intake installation Chapskac B14 95-99 chassis 28 Nov 7th, 2003 02:22 AM
1.6L sentra air intake questions smithsil Naturally Aspirated 14 Sep 18th, 2002 10:38 AM
