Bear with me here. I'm a girl who knows very little about cars, but I want to learn and I want to fix this myself. Only things I've done to a car before (not this one) is install a boost gauge and oil changes.
I've got a 200SX SE-R with 45k miles. I've got a small coolant leak. First sign was a bit of coolant pooled by the lip of the shield underneath the car below the alternator. I checked my overflow and it was very low. I refilled it, and in the 2 weeks since then, its gone down about 3/4 inch. If I feel the bottom of the hose where it attaches to the thermostat after a drive, theres usually one drop of coolant. Even when the hose is dry and the car's been sitting for a while, I can still smell coolant on my hand after I touch it. I left something under the thermostat overnight to see if it leaked, and it didn't. So either its not the right place or it only leaks when its hot. Tried tightening the hose to the thermostat, didn't make a difference.
I'm thinking I should replace the hose and thermostat. Do you think this will fix the leak? Should I only replace one, and not the other? Or could the problem be somewhere else? I know this isn't a huge problem, but its driving me CRAZY and I must get it fixed ASAP.
