Coolant leak? coolant in exhaust? - Nissan Forum
post #1 of 9 Old Jan 3rd, 2006, 07:44 PM Thread Starter
Angry Coolant leak? coolant in exhaust?
I noticed a small leak on the engine that is definately coolant. Looks like a hose leak (those hose that is connected to engine)
I also noticed yellow/green liquid comming out from my exhaust. Small puddle on the garage floor.
Dont see any noticable smoke out of exhaust.
Dealer says its only a leaky hose (they have to pay for the fix so of course its just a hose)
any suggestions
lg2005 is offline
post #2 of 9 Old Jan 3rd, 2006, 11:04 PM
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
coolant out of the exhaust?? you mean the very end of the tailpipe?? or something under the hood?? my first impression was a leaking head gasket.
Naturally aspirated autocross car.............naturally.
Retired STF champ car.
azkicker0027 is offline
post #3 of 9 Old Jan 4th, 2006, 02:56 AM
Nissan Addict
yea, is it actually coming out of the tailpipe ?
Cause fluid travels, so if its actually leaking from somewhere else and just traveling along the pipe or something, thats different .. .
People that owe me money and/are SCAMS::
thestunts200sx is offline
post #4 of 9 Old Jan 4th, 2006, 05:50 AM
EvilPotato's Avatar
i was gonna start a new thread but lg2005 seems to be having the same problem as me. I have a '96 200sx se, A/T, 134,xxx miles on it. My exhaust blows out a HUGE thick cloud of white smoke that smells like burning oil when i rev up at around 3k rpm, water slowly drips at the tailpipe, no water present in oil and coolant doesn't bubble when i take off radiator cap. The white smoke first appeared 3 weeks ago the car was at 6k rpm getting on the freeway. The car started losing power so i got ready to merge to the slow lane and i couldn't see anything through the mirrors cause of the smoke. Any idea what happened?
"...and the Lord said to John, Come forth and ye shall receive eternal life, but instead John came fifth and won a toaster."
EvilPotato is offline
post #5 of 9 Old Jan 4th, 2006, 12:12 PM
I Live Here
IanH's Avatar
Sorry I cant tell from your description wether this is a blown gasket or an engine mechanical failure.
But can tell you the only time i have had that much smoke was from a Z28 Camero that I blew the rings out off a long time ago.......
Cant tell you how, the mods will have my guts.....
Is there a statute of limitations on the forum....?
2003 Pathfinder from 2004 SE 4WD
1997 SER 5sp Manual from new Rear Ended 2009 !!
Gone to the Knacker yard...
New ride 3.0 manual RWD not a Nissan !!! Gone 2016 from Hail damage.
1997 Sentra GXE from new .... Sold 2008
2001 Sunny N16 RHD from new (N16 Nissan Bluebird Sylphy) Sold
IanH is offline
post #6 of 9 Old Jan 4th, 2006, 01:22 PM
Did you recently have an oil change? The only time I saw smoke like the was on an old covair I had. I had the oil changed and they didn't drain out the old oil so I had 8 quarts of oil and at high speed it looked a James Bond smoke screen. [what happened was they drained the transmission not the oil - the transmission plug is near the oil plug and the transmission died a week later].
Widget is offline
post #7 of 9 Old Jan 4th, 2006, 08:18 PM
EvilPotato's Avatar
anyone heard of, or tried thermagasket?
post #8 of 9 Old Jan 4th, 2006, 10:02 PM
Cone Dodger
well, if it's that bad, i'd do a cylinder leakdown test to see if oil has the chance to get past the piston rings. as for the valve seals, i'm not sure what method can be done to check those for leaks.
post #9 of 9 Old Jan 5th, 2006, 05:22 PM
EvilPotato's Avatar
so how do i go about doing a cylinder leakdown test? i found this
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Exhaust Manifold Leak Diagnosis dwj119 Pathfinder 5 Sep 25th, 2007 09:39 PM
Cat-Back Exhaust Systems Comparisons alexnds J30 1989-1994 Chassis 3 Nov 2nd, 2005 01:35 PM
Exhaust leak????? 87300zx Z31 300ZX(T) 5 Aug 23rd, 2004 01:09 PM
Exhaust Leak On My SE-L clsindustries SR-Series Engines (DE/VE) 1 Apr 7th, 2004 12:20 AM
Will exhaust leak cause lean WB O2 reading ck03specv QR25 2.5L Engine 11 Jul 9th, 2003 03:49 PM
You may post new threads
You may post replies
BB code is On
