Old Oct 12th, 2005, 03:25 PM   #1 (permalink)
SilverSentra99
Nissan Guru
SilverSentra99's Avatar
Send a message via Yahoo to SilverSentra99
differences after cv axle replacement
I just got my cv axles changed both at the same time, my boots were cut so i got whole new axles for 45 a piece. anyway there on now and i hear and feal a vibration at a certain speed its like when i hit fifty. and its only when i go int Overdrive that i feal it . did my mechanic do anything wrong. i watched them go in and it only took one tap with a hammer to put them back in it was like a 15 minuite job. everything works great it turns good and accelerates, better now but ther is that vibration or sound i hear and feel that has me worried. what do you all think
1999 Nissan Sentra GXE Limited Edition Auto GA16DE
See My Custom RAM/Cold Air Intake ,multicolor LED Undercar Kit Optix,K&N Filter Charger, Stock Gun Metaled Rims @ http://www.cardomain.com/ride/261891
SilverSentra99 is offline   Reply With Quote
Old Oct 13th, 2005, 01:27 AM   #2 (permalink)
azkicker0027
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
well, could also be a simple wheel balance issue. are they aftermarket axles??
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://www.200sxonline.com/community/
azkicker0027 is offline   Reply With Quote
Old Oct 13th, 2005, 01:28 AM   #3 (permalink)
konfuzion3
I Heart Your Fake Wheels
konfuzion3's Avatar
Did you have an alignment done afterwards?
:showpics: kOnFuZiOn3kOnFuZiOn3konfvzion4@msn.com
konfuzion3 is offline   Reply With Quote
Old Oct 13th, 2005, 09:10 AM   #4 (permalink)
SilverSentra99
Nissan Guru
no alignment done yet im getting my falken zeix 512s today and will get one done. and yes they are aftermarket. but i did notice that in the FSM manual and i watched them put them in There were no Dynamic Dampers on them . The dynamic damper is a circular peice. I t looks like its rubber. but it does something important . because the FSM said to put new ones on when you replace the axles. so im going to see if i can locate some. It goes in the middle of the shaft. and i guess that its something i need to have on the new ones. thanks for the ideas and ill update you all tonight after i get the tires.
And if anyone knows what the heck a dynamic damper does . id love to know.
Axle removal / cv joint dissembly help needed patrick leber J30 1989-1994 Chassis 3 Oct 13th, 2005 10:46 AM
cv boot replacement (not removing driveshafts) copperlite B11/B12/KN13 82-90 chassis 14 Sep 17th, 2005 01:41 AM
CV Axle stuck in hub nismo b14se-r B14 95-99 chassis 4 Jul 8th, 2005 10:49 PM
CV Axle Replacement daconch B13 91-94 chassis 5 Jan 24th, 2004 10:11 AM
CV axle replacement himilefrontier B14 95-99 chassis 8 May 21st, 2003 10:05 PM
