Old Oct 11th, 2005, 04:03 PM   #1 (permalink)
prism_101
problems with suspension?
I am having problems with my suspension (I think). When I am making long left turns while accelerating the car is fine. When I let off the accelerator iin these turns the car suddenly seems like it is hydroplaning to the right. Thats exactly what it feels like. Its been getting progessively worse. The steering wheel also pulsates somewhat during normal driving. Any suggestiong would be awesome
prism_101 is offline   Reply With Quote
Old Oct 11th, 2005, 04:26 PM   #2 (permalink)
thecolonelcm
Still here
thecolonelcm's Avatar
Send a message via AIM to thecolonelcm
pulsating wheel... that makes me think you have a power steering leak. i had that problem in my Z.
Daddy: Oh, watch out, Melinda! Once a woman is introduced to Colonel Angus, she'll settle for nothing less.
Melinda: Daddy, they say all the womenfolk just love Colonel Angus!
thecolonelcm is offline   Reply With Quote
Old Oct 11th, 2005, 04:32 PM   #3 (permalink)
prism_101
i had some people tell me that it might be in my transmission, specifically my differential. On top of all this, it groans a little when i back up (not necessarily with it in reverse gear) but only for about a foot or two.
Old Oct 12th, 2005, 05:21 AM   #4 (permalink)
scooterbob
Send a message via MSN to scooterbob
Start with the easy (and cheap) things first. Check all your lugs nuts to make sure they are tight. Then check your tie rod ends. One good way to see if there is play in your steering is to jack up your front end and wiggle each tire in all directions to check for excessive play or any popping sounds. When is the last time you had an alignment check? Are your tires worn unevenly?
Hope it helps, good luck.
2008 Versa!
'95 200sx S-er: Homemade intake w/filter, 91 cams, advanced timing, 4 ga. grounding kit. (possibly for sale now)
If you ain't pinging redline MOVE! ---Bob
scooterbob is offline   Reply With Quote
Old Oct 12th, 2005, 01:49 PM   #5 (permalink)
sercool
Sounds like you need your tires balanced too.
sercool is offline   Reply With Quote
Old Oct 12th, 2005, 03:34 PM   #6 (permalink)
makaveli
Nissan Fanatic
i actually have been having the same problem, and i know there is a power steering fluid leak, from the hose coming off the resivoir to to back of the engine tight under the TB. i tightered the clamps but it still leaks, i fill it mabye 1/2 inch every week or week and a half
makaveli is offline   Reply With Quote
HELP suspension problems Pzych0 B11/B12/KN13 82-90 chassis 10 Sep 7th, 2005 01:53 AM
Problem/No Problems Zac QR25 2.5L Engine 69 Aug 25th, 2005 07:41 PM
B14 Suspension thoughts (No, not about coilovers or springs) Acceler8ter Suspension & Brakes 1 Jun 14th, 2005 06:52 PM
Wow - I think it's time for a suspension upgrade ;) rbloedow Suspension & Brakes 4 Dec 13th, 2003 09:42 PM
My Nissan 350Z Lemon w/Many Problems! C1 Bender Z33 350Z 2003+ 8 Aug 10th, 2003 03:43 PM
