Old Sep 28th, 2005, 10:02 AM   #1 (permalink)
LONDONDERRY
Nissan Addict
LONDONDERRY's Avatar
need some help with a protential starter problem
Hello, currently I own both a 96 Altima and Sentra both GXE models. Most of my posting in this forum are in the Altima section, if you care to read, because my Sentra has been sitting on the sidelines for 10 months and now I want to bring it back to life. Well here is my question.
Occasionally, went I first start the sentra, the engine would not turn over. It would rotate but thats about it. I believe it is the starter, but I am not too sure. If I let the car sit for a day or two then it will start up okay. The car has been completely tuned up since last October and the battery is okay. Any suggestions?
reagrds
Frank
LONDONDERRY is offline   Reply With Quote
Old Sep 29th, 2005, 06:05 AM   #2 (permalink)
LONDONDERRY
Nissan Addict
reagrds
Frank
what no takers on this subject?
Old Sep 30th, 2005, 05:29 AM   #3 (permalink)
Sethticlees
Nissan Addict
Sethticlees's Avatar
If you can hear the engine crank over then your problem is not your starter.
May be fuel, spark, or something else.
Sethticlees is offline   Reply With Quote
Old Sep 30th, 2005, 06:04 AM   #4 (permalink)
LONDONDERRY
Nissan Addict
I noticed that when the car does not turn over but just rotates that there is slight smell of gas and in addition, if I keep trying to start it the starter motor sounds like it is winnding down.
Old Sep 30th, 2005, 08:45 AM   #5 (permalink)
IanH
Post Freak
IanH's Avatar
If the starter sounds like its winding down then either the battery is weak or something is getting hot and causing a bad connection. If you are really sure the battery is good is charged or passes testing, then check the battery connections are clean by removing them and see if this does it.
You can also put a voltmeter across the battery posts (not the clamps,) and check the voltage at the battery before the connections and cables, solenoid etc and this will tell you if the battery is in poor shape OR just discharged.
Look for about 13 V before you get someone to turn the key and above 9 or 10V while cranking, and watch for voltage dropping off with time.
Let us know how you are doing.....
1997 Sentra GXE .... SOLD
1997 S-ER 5 sp yea !!!
2003 Pathfinder SE 4WD
IanH is offline   Reply With Quote
Old Oct 9th, 2005, 11:24 AM   #6 (permalink)
sentraGXE_KY
something different
Look I just went though the SAME THING!!! I bought a new starter, Problem solved! Mine wouldn't even make a noise when I turned the keys, all the accessories would come on but thats it. I pout a new starter in it and boom problem solved! Good Luck!
sentraGXE_KY is offline   Reply With Quote
Old Oct 9th, 2005, 01:02 PM   #7 (permalink)
SupraMK3
SupraMK3's Avatar
If your starter turn your engine over then it's probably not your starter. It could be your battery or starter is on the way out. Check all your wiring connection to make sure it's clean. A faulty ground wire connection will cause you to do that too. Have you change out your fuel filter? Timing belt? Could be off a tooth. If the car doesn't start then it's fuel, air, or spark.
SupraMK3 is offline   Reply With Quote
Old Oct 9th, 2005, 03:54 PM   #8 (permalink)
Twiz
TwiztidKidd
Twiz's Avatar
Pull out all spark plugs and squirt some motor oil in each cylinder. With ignition off and trans in neutral... crank the engine by hand using a wrench/ratchet. Also try to determine if you get spark... clean the distributor cap and rotor if necessary. Check the condition of your oil.
Twiz is offline   Reply With Quote
Old Oct 9th, 2005, 05:22 PM   #9 (permalink)
p_reed
Good Call
p_reed is offline   Reply With Quote
Old Oct 24th, 2005, 07:39 AM   #10 (permalink)
LONDONDERRY
Nissan Addict
Originally Posted by p_reed
Good Call
Here's an update. Turns out the battery was to weak to crack over the engine, I replaced and it started up. However, in order for the engine to crank over I had to floor the gas pedal while turing the ignition. This took a few tries Once it started, after 10 months of no use, it ran fine. At this point I don't believe that the starter motor is cause the intermittent starting problem. I think its in the fuel delivery system. Any advice on where to start.
Finally, I was stupid and left the parking brake on for the last ten months. Now I can't get the rear drums brakes to disengage. I took the center console out inspected the parking brake wire. How do you release a frozen parking brake line, because, I can't take the drums off if the brakes engaged to it.
Thanks
Frank
Old Oct 24th, 2005, 09:16 AM   #11 (permalink)
IanH
Post Freak
IanH's Avatar
Thanks
Frank
If the engine floods due to repeated attempt's to start or you start and move 20 ft and turn off the procedure to start is to hold the pedal to the floor and crank the engine over with the starter. This tells the ECU to not add gas so you can clear the flooding and start.
Now the cars runs. Once you have driven it and got the engine nice and hot it should start ok.
If the rear shoes are seized I suggest you take off the wheels and push on the hand brake lever at the back of the drum. Then back off the adjuster through the hole covered by the rubber plug.
You should be able to remove the drums then. Give them a tap ( but don't hit the cast iron too hard as it will break)
You can also use a puller or bolts in the threaded holes that is normally provided.
Also put the wheels back and try moving the car ??
Good Luck......
Old Oct 24th, 2005, 11:27 AM   #12 (permalink)
LONDONDERRY
Nissan Addict
Good Luck......
Okay another update. I pulled the spark plugs out and one of them is coated with oil near the electrode. So now I'm thinking that the reason I have this intermitted starting issue is because of the oil. I read through the haynes manual and there are two sections of interest if I want to fix the problem. One is to remove the valve cover and replace the spark plug and valve cover gasket and the other section is to replace the valve seals, which is much more involved. Any opinions on this subjest?
Thanks
Frank
Old Oct 24th, 2005, 11:33 AM   #13 (permalink)
Twiz
TwiztidKidd
Twiz's Avatar
Thanks
Frank
The problem is internal... change the oil and oil filter
Old Oct 24th, 2005, 01:19 PM   #14 (permalink)
LONDONDERRY
Nissan Addict
did that all ready
Old Oct 24th, 2005, 11:07 PM   #15 (permalink)
IanH
Post Freak
IanH's Avatar
Thanks
Frank
So have you driven the car and got it hot to burn off all the excess gas and oil from your starting problems ?
Do that first then pull the plugs and see if you still have a problem.
How many miles on this engine ?
What happened with the rear brakes ?
Good luck.....
Is this a starter problem? alkon GA16DE 1.6L Engine 4 Aug 19th, 2005 11:23 AM
Starter installation - SR20 redhat-z B13 91-94 chassis 1 Feb 17th, 2005 10:53 PM
Starter Motor Problem... beethaniel SR-Series Engines (DE/VE) 6 Apr 24th, 2004 02:59 PM
starter keeps going out sno GA16DE 1.6L Engine 1 Mar 7th, 2003 06:17 PM
starter problem? roffclem B14 95-99 chassis 4 Sep 2nd, 2002 01:18 AM
