Old Jul 26th, 2005, 12:05 PM   #1 (permalink)
kebas239
dash/interior lights wont work
Anyone know about the funky wiring for the lights in a 95 sentra? I disconnected my head unit to install a new one, person who previously installed the head unit had problems with this lighting too. He eventually got it working somehow (but the slider that dims the console lights didnt work anymore, but thats it). I set up the radio - everything works but the interior lights (cluster lights and shift lights - other interior lights work). I tried everything. When you connect the illumination light wire from the wiring harness to the battery light or the ignition light they go on. Otherwise, getting them to go on with the lights does not work. Anyone know how this might be resolved or how i could reach the lighting wire. I tried unplugging all the wires under the dash and near the ECU and none of them turned the exterior lights off.
kebas239 is offline   Reply With Quote
Old Jun 8th, 2007, 05:17 PM   #2 (permalink)
shagpal
I just got the same problem. no interior light illumination, nada. no dimming from the dimmer. any suggestions?
I have a 95 sentra gxe.
shagpal is offline   Reply With Quote
Old Jun 12th, 2007, 04:26 AM   #3 (permalink)
runningcold
fwiw, i had this problem a month ago...started with my dash lights, then my tail lights. it turned out to be the driver's side power window console shorting out the whole car.
runningcold is offline   Reply With Quote
Old Jun 12th, 2007, 03:17 PM   #4 (permalink)
Burn 17
Nissan Fanatic
Burn 17's Avatar
Send a message via MSN to Burn 17
pull off your dimmer and cheack conections and the potentiomiter, you may have a short to ground.
NEW!!1987 300ZX
200 sx auto cross beast--
Intake, Front and Rear Strut bars, Major exhaust leak.98style tail lights, clear corners, and halo angle eyes, Hot Shot headers/Downpipe(still need money for the rest of it)
Mazda B2200 Mini Truck
Burn 17 is offline   Reply With Quote
Old Jun 12th, 2007, 04:06 PM   #5 (permalink)
Tavel
Destroyer of worlds.
Tavel's Avatar
Send a message via AIM to Tavel
yeah, it's probably a short to ground on the stereo's wiring harness.
I had a similar deal where the dash lights fuse kept blowing, taking the tail lights with it (brake lights still worked). I'd be interested to see if your tail lights are out as well.
It turned out that one of the left over wires on the stereo's wiring harness was randomly shorting to ground, depending on how the wires were knocked around during driving that day. I tipped all the loose wires with shrink wrap and the problem went away.
(I say it's probably on the stereo wiring harness because that's what you goofed around with to cause the problem. I could be somewhere else, as with Burn 17)
I'll edit YOUR signiture!
Tavel is offline   Reply With Quote
Old Jun 13th, 2007, 01:10 AM   #6 (permalink)
Burn 17
Nissan Fanatic
Burn 17's Avatar
im not sure how the sterio would affect this, as far as i know the only wires involved with the sterio are the turn signals and hazards
but what the hell check it out
i was saying the dimmer on the right side of your stering wheel that adjusts how bright your inside lights are
NEW!!1987 300ZX
Old Jun 13th, 2007, 12:14 PM   #7 (permalink)
Tavel
Tavel's Avatar
your message totally said something different when i wrote my reply! lol
The stereo affects it because it's all on the same circuit. If you pull the dash fuse, you don't get any lights, stereo, or tail lights. A short on the stereo is essentially a short on that entire circuit.
I also resoldered the wiring harness and upgraded the electrical tape to shrink tubing (the original installer...me...did a shoddy job the first time), and tipped all the loose ends with shrink tubing. I made absolutely sure it wasn't shorting ANYWHERE on the wiring harness, and the problem is resolved.
I would suggest double checking the wiring harness before moving over to the dimmer switch (I originally though MY problems were from the dimmer switch too), because, as i said, you were messing around with the stereo to cause the problem...that's a good place to look for a solution.
BTW: this was on a 98 sentra...not the '92 as in my sig thing.
Old Nov 12th, 2007, 01:23 PM   #8 (permalink)
melchieor
fuse?
Where can I find the dash/tail light fuse? Is it under my steering wheel?
melchieor is offline   Reply With Quote
Old Nov 12th, 2007, 02:58 PM   #9 (permalink)
melchieor
I heard that it might be under the hood by the battery tucked under the fender but i am not sure.. anyone know?
electrical problem--accessories do not work but car runs fine 200sxman B14 95-99 chassis 13 Feb 8th, 2005 12:19 PM
Prison vs. Work Bumpin Off Topic 11 Oct 15th, 2004 09:18 PM
Low Beams Headlights don't work Tuz A33 2000-2003 Chassis 2 Oct 4th, 2004 09:42 PM
Turn signal does not work after a few minutes of running calfaro General Discussion 6 Aug 27th, 2003 06:16 AM
Blew something on the way to work NeonLVR E/CA-Series & GA16i Engines 7 Jan 22nd, 2003 11:01 AM
