FAULTY FUEL PUMP & FUEL PRESSURE REGULATOR - Nissan Forum
post #1 of 5 Old Jul 23rd, 2005, 10:18 PM Thread Starter
Send a message via Yahoo to montikar
Question FAULTY FUEL PUMP & FUEL PRESSURE REGULATOR
What are the signs when any or both are going bad? I have a 1998 JDM sunny with the GA15DE engine which when started sounds like it is missing, after a while it will even out but whe under hard acceleration it starts to hold back and if i ease off the gas it pcks up. have changed plugs , wires , tps and checked the timing. It hunts sometimes in the 2400-2600rpm range. A mechanic told me the pump is going so the engine is leaning out when under pressure cause it is not getting enuf gas.
Need some advice asap.
thanx
montikar is offline
post #2 of 5 Old Jul 24th, 2005, 01:26 PM
thanx
well u have to go for the basics for starters check furl filter if is clogged
check the sound of the fuel pump for something abnormal like
if it sounds rough or if is taking too long till fill up the lines
in my sentra the pump takes long to fill up the lines but never hessitates
i say check pressure on the lines or in the injectors that will give u an idea
pester is offline
post #3 of 5 Old Jul 27th, 2005, 09:49 AM
I Live Here
IanH's Avatar
I agree change the Fuel filter first, this is what a blocked filter does, and its the cheapest.
Then move on to the more complicated stuff....
Good Luck....
2003 Pathfinder from 2004 SE 4WD
1997 SER 5sp Manual from new Rear Ended 2009 !!
Gone to the Knacker yard...
New ride 3.0 manual RWD not a Nissan !!! Gone 2016 from Hail damage.
1997 Sentra GXE from new .... Sold 2008
2001 Sunny N16 RHD from new (N16 Nissan Bluebird Sylphy) Sold
IanH is offline
post #4 of 5 Old Jul 13th, 2011, 04:13 PM
thanx
i have the same problem with my 1999 nissan sentra. did changing the fuel pump fix the problem?
JScrylla is offline
post #5 of 5 Old Jan 9th, 2012, 11:41 AM
What pressure is correct frm the pump?
crossbreed is offline
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
New fuel pressure regulator design: Opinions Please synapse Forced Induction & Nitrous Oxide 16 Sep 1st, 2005 02:20 AM
What Fuel Pressure Regulator is everyone Running Rex2NV SR-Series Engines (DE/VE) 4 Aug 20th, 2002 07:55 AM
b&m fuel pressure regulator nss200sx B14 95-99 chassis 0 Aug 13th, 2002 11:38 AM
70 Shot on a 2k2 Maxima!? ChiTwista Forced Induction & Nitrous Oxide 12 May 26th, 2002 01:51 AM
Fuel pressure regulator Japie Naturally Aspirated 0 May 21st, 2002 10:58 AM
You may post new threads
You may post replies
BB code is On
