» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B13 91-94 chassis
Old May 29th, 2002, 04:21 AM   #1 (permalink)
Define_Sentra
Guest
Posts: n/a
Question Help on my Radiator
hey can anyone help me cuz my Radiator eats up so much Anti coolant i gotta keep putting in, when i dont put any it smokes, i tried looking for leaks under neath the car, but there isn't any
Old May 31st, 2002, 03:42 AM   #2 (permalink)
Subculture
Send a message via AIM to Subculture Send a message via Yahoo to Subculture
So what you're saying is that your coolant level is constantly low, even after you refill the resevoir?
Thomas Fox
93 NX2000
Subculture is offline   Reply With Quote
Old May 31st, 2002, 03:47 AM   #3 (permalink)
Define_Sentra
Guest
Posts: n/a
hell yah its gone everytime i put my A/C on even for a couple minutes...its all ready drained
Old May 31st, 2002, 04:11 AM   #4 (permalink)
WaLdo98
WaLdo98's Avatar
Send a message via AIM to WaLdo98 Send a message via MSN to WaLdo98
Are you leaking any coolant?? I had a similar problem where my coolant was leaking and I was always running low. My problem turned out to be a leaking water pump that I had to replace.
03 Vibrant Blue Auto SE-R w/SP
Protech Fabrication
WaLdo98 is offline   Reply With Quote
Old May 31st, 2002, 08:17 AM   #5 (permalink)
Define_Sentra
Guest
Posts: n/a
awww man dont tell me its bad like that.....im gonna go check on that in the chiltons book.
Old May 31st, 2002, 11:01 AM   #6 (permalink)
Subculture
You should be able to see a coolant leak.
Check all of your hoses.
Check the front of your motor.
If you still can't find the leak, pull your dipstick. If the oil looks milky white, you've found your coolant leak.
Thomas Fox
93 NX2000
Old May 31st, 2002, 11:18 AM   #7 (permalink)
slvrsentra
Does this happen ONLY when you turn on the a/c?? Or does it drain if you dont use the a/c at all??
89 Mustang GT "power on tap"
13.304@102.29
slvrsentra is offline   Reply With Quote
Old May 31st, 2002, 04:02 PM   #8 (permalink)
Define_Sentra
Guest
Posts: n/a
it drains like major after at least 2hours after the a/c was on, im guessing there's a hole somewhere in the hoses
Old Jun 9th, 2002, 07:06 AM   #9 (permalink)
Hawaii_SE-R
Nissan Fanatic
Hawaii_SE-R's Avatar
Location: Stuck on a Rock in the middle of the Pacific Ocean.
Try this as it may be a very simple solution to a very simple problem. Replace your radiator cap.
http://www.serca.org/hawaii/DCs_sig.jpg
1991 Aztec Red SE-R: JWT ECU, S3 Cams, PP, Motor Mounts; Stillen STB, Intake; Hotshot Header, CAI; UR 3 Pulley set; Custom exhaust w/ Sebring muffler; Eibach Prokits Springs & Roadhandler Struts?; Random Thoughts Rear STB; Magnecor wires; AMSOil; AD22VF brakes; Metal Master pads; Ford High-Performance Synthetic brake fluid; SMC SS brake lines; LoTek A-pillar Gauge Pod w/Autometer gauges; Techtom MDM-100; B14 SE-R rims w/ S0-3s; Tsuru headlights w/Silverstars; Hella FF50 Driving Lights; N-Tech Subframe connector; Baker Precision Silicone radiator hoses; NX center counsol
1991 Vail White SE-R: K&N drop-in air filter, oil filter and a lot of AMSOil
Parts on the side: Unopened ES Bushing Master Set; Unopened SMC Short Shifter; Used GC coilover set; New ZEX/Compcams ultra-light flywheel; Used SS Nakayama muffler
Hawaii_SE-R is offline   Reply With Quote
Old Jun 9th, 2002, 06:41 PM   #10 (permalink)
Define_Sentra
Guest
Posts: n/a
I found the problem, but its major. it has a crack right on the front of the radiator the plastic part. So i guess my luck now is getting a new Radiator
Old Jun 9th, 2002, 07:34 PM   #11 (permalink)
Hawaii_SE-R
Nissan Fanatic
Ouch! I had that same problem last year on my Nissan Motorsports radiator. Never understood why they had plastic ends. I now have an all steel radiator from Import Parts Hawaii. I think it was less than $150.
Old Jun 9th, 2002, 07:46 PM   #12 (permalink)
Subculture
Contact Greg Vogel at Mossy Nissan.
Thomas Fox
93 NX2000
cheap radiator upgrade holy200sx B14 95-99 chassis 12 Nov 8th, 2003 01:48 AM
radiator problems!!! projectnx GA16DE 1.6L Engine 9 Oct 6th, 2003 03:39 PM
1986 Nissan Pulsar NX radiator question - Critical tsmurray B11/B12/KN13 82-90 chassis 4 Jul 29th, 2003 08:08 AM
1986 Nissan Pulsar NX radiator question - Critical tsmurray B11/B12/KN13 82-90 chassis 3 Jul 28th, 2003 09:25 AM
Interesting radiator info, some may know already Nismodriver B11/B12/KN13 82-90 chassis 1 Mar 30th, 2003 01:52 AM
