Hi all. I am a new member, royn01 from New York. I drive three nissans. 1994 Sentra, 2001 Altima and 2004 Quest. I do most of the regular stuff myself, except when I have to raise the car and beyond.
In my 1994 Nissan Sentra, the seat belt light stays on for about 2 minutes after I start the engine. During the last cold spell, the light will go off after the buzzer is off (within 6 sec of starting the engine). But after about 10 minutes of driving, the buzzer will come on and the light will stay on for about 2 min. If I take off the lap belt, the light will come on and stay on until I put it back on. If I take off the shoulder belt, the buzzer will come on and light stays on until I put the belt back on the automatic mechanism on the door. I bought the car recently. It runs and looks great. I would appreciate any help with fixing the problem. Thanks.
I have checked all the fuses; they seem to be in good condition. Could there be problem with the relay. The drawing of electrical lines in the owners manual shows the automatic seat belt power line is connected through a relay. I don't know whether the relays stop working under certain conditions, where are they located, and how to replace them successfully.
is the door open ever. or the door light on? i know whenever my door is open (75% of the time due to bad hinges) the seatbelt light goes on with the door light (i have manual belts tho)
91 sentra 2dr E 4 spd......getting stripped and junked...mission aborted
91 NX2k auto eggshell white :cool:
mods: uh...prothanes for when the motor goes in...otherwise stock
Door light works with all four doors. Door open, light is on; door close, light is off. Yes, when the passenger side door is opened and closed while the engine is on, the buzzer comes on and again the seat belt light stays on for about 2 min. Sorry to bother you guys; but there must be a way to resolve this problem.
My '94 SE-R had manual belts. If the passenger belt was not clipped, the buzzer and light would go for about two minutes. It eventually went off but I just left the belt hooked to silence the dumb thing. I had to remember to unhook the belt before a passenger tried to get in, though. The owner's manual indicated this was normal behaviour.
Bruce in Houston
I have checked the belts. Passenger side shoulder and lap belts do not have any effect on the buzzer or the light. I started the engine with the passenger side belts hooked. Seat belt light still remained on for 2 min. While the engine was running, I unhooked and hooked both passenger side belts and nothing happened. Neither the light nor the buzzer came on. On the other hand, unhooking the driver's side lap belt triggered the light to come on and unhooking the Driver's side shoulder belt triggered the buzzer. Not sure what to check now. Thanks for the input everybody.
Hi
I have 94 LE which has automatic belts. It keeps making that weird buzzer noise at random. Cannot tell when. Also the seat belt light comes on all the time. What could be the reason for this?
If I cannot fix can someone tell me how to remove the buzzer completely. It is quite irritating that the buzzer keeps chirping.
Thanx
94 Sentra LE, 170k+,Tan,GA16DE stock
you might have a bad relay. all i do is un plug the connection under the seat, the will fake the computer out, and your seatbelt light wont come on. Its the wire that comes out of the rug that plug into another plug under the driver seat.
every single nissan ive owned ive done it to it, and wil do it to all other nissan i might own
