Old Jan 29th, 2005, 07:32 PM   #1 (permalink)
jammo
Send a message via AIM to jammo Send a message via MSN to jammo Send a message via Yahoo to jammo
problem
TONS of problems tonight with my SE-R, 1992.
died last night on the way home.
checked battery, alternator, and starter. they are okay.
checked all relays.
no power to anything in the car, no light, no radio, no dome light, etc.
when the key is turned to top position, the relay on the bottom of the fuse box, clicks, but dot not turn on.
is if the bottom of the 4 relays near the fuse box under steering column
when the key is off, the ECU is buzzing.
and check warning light AND the battery light come on, without the key!
WTF!
1992 Sentra SE-R Clįssico
jammo is offline   Reply With Quote
Old Jan 29th, 2005, 07:33 PM   #2 (permalink)
jammo
i found some wiring diagrams for it.
see if this helps:
http://jammo.net/images/my_SE-R/SR20...g_diagram1.JPG
http://jammo.net/images/my_SE-R/SR20...g_diagram2.JPG
Old Jan 29th, 2005, 09:42 PM   #3 (permalink)
Token Moron
My ass, your face
Token Moron's Avatar
Send a message via AIM to Token Moron Send a message via MSN to Token Moron
the battery may be good, but how are the terminals? just because they are on the battery, it doesnt mean theyre making a good connection. remove BOTH battery terminals, clean them up and connect them nice and tight, then try it again. if that doesnt work, it sounds to me like there is something in your car that is grounding out(more than likely the main power harness)
91 se-r : sr20det= the beast
96 sentra : ga16de= pimpness
00 frontier : ka24de= tow truck
01 sentra : gq18de= stock mofo
Token Moron is offline   Reply With Quote
Old Jan 30th, 2005, 12:39 AM   #4 (permalink)
shingouki1
Send a message via AIM to shingouki1 Send a message via Yahoo to shingouki1
check all the fuses. do a continuity test on them with a multimeter. the bottom relay is ignition relay1. the second one is accesory relay1 the third one is ignition relay 2 and the one at the very top is the window defroster relay. if you dont hear your accesory relay or ignition relay 2 clicking when you turn the key then you may have a short somewhere causing the relays not getting power. but you can check for ground problems. you might want to pull the codes on the ecu as well.
shingouki1 is offline   Reply With Quote
Old Jan 30th, 2005, 04:21 PM   #5 (permalink)
jammo
Checked all of the fuses (multimeter) and they all seem to be good. All battery connections and grounds are good in the engine compartment.
Key out = CEL, Battery light, no radio, lights, etc. Clock in dash works until I try to turn on lights, then all electricty seems to stop until the key is turned.
Key "Start" Postion = Bottom relay (next to inside fuse box, there are what seem to be 4 relays, top one brown, 3 below blue) clicks as long as key is in start postion. Changed this relay, no difference.
Key out after relay clicking = Very fast clicking from the ECU (on floor in front of radio) and have to disconnect the battery for it to stop.
Any and all help would be greatly appreciated.
Old Jan 31st, 2005, 05:46 PM   #6 (permalink)
jammo
*bump*
need to get my car running.
Old Jan 31st, 2005, 06:26 PM   #7 (permalink)
jammo
a friend recommended swapping the ECU from another Sentra, preferrably a SE-R, to mine.
basically to eliminate my own ECU as the issue.
if the donor ECU works, than mine is bad, and ill need to replace it.
if the donor ECU doesnt work, then something is bad between the ECU and the relays benath the dash.
Old Feb 1st, 2005, 12:34 PM   #8 (permalink)
jammo
awh come on fellas.
three days and no help?
we are totallly stumped, and i would hate to take my car to the strealership.
Old Feb 1st, 2005, 02:59 PM   #9 (permalink)
licklemanbklyn2g3
licklemanbklyn2g3's Avatar
Send a message via MSN to licklemanbklyn2g3 Send a message via Yahoo to licklemanbklyn2g3
check ur starter
Team N.V.
Traffik Blockin NYC
licklemanbklyn2g3 is offline   Reply With Quote
Old Feb 3rd, 2005, 10:42 PM   #10 (permalink)
jammo
Originally Posted by licklemanbklyn2g3
check ur starter
have aready.
seems fine.
ive got a chilton & a haynes manual somewhere at my moms house.
just gotta find a way to get to them, without my car :|
ill find something out.
Old Feb 3rd, 2005, 10:53 PM   #11 (permalink)
ifoam
i think this happened to me
have someone start the car as you jiggle the power cables. i had that problem also.
with no key, the clock would work, if i turned the key, it would die. if it went to start, the ecu would click.
the battery cables were loose. make sure they are on tight at the battery and at the end of them
ifoam is offline   Reply With Quote
92 240SX: Intermittent Shift Problem 240rocker S13 240SX 1989-1994 7 Jun 8th, 2005 09:59 PM
NX2000 Cold Start Problem Seeking Help lucifer SR-Series Engines (DE/VE) 4 Mar 4th, 2005 08:18 AM
Problem: Rear Brake Noise wayne2k1 Suspension & Brakes 13 Aug 1st, 2003 12:57 AM
Hi all, I'm new here. Got a problem with my B14, pls help. Mayonaise B14 95-99 chassis 8 May 12th, 2003 06:03 AM
CA18DET Motor Swap Problem Zushi S13 240SX 1989-1994 3 May 7th, 2003 04:15 PM
