Old Jan 18th, 2005, 10:37 AM   #1 (permalink)
FarAway
New Power Steering Pressure hose = more noise!
I had a leak in my pressure hose for about 2 months before I got around to fixing it (Lame excuse, but I didn't have a big enough socket!). (94 sentra 1.6 140,000 miles)
As it got low, it would whine, then it would be better when I added fluid.
I finally added changed the hose, and the leaking stopped, but now the whining is worse! Even slight turning of the wheel causes loud whining.
Edited to add: Although it's noisy, the wheel turns freely.
I searched similar threads here, and the best I came up with is change the fluid and make sure the car is warm. I haven't tried changing the fluid because i put about 3-4 quarts in over the past 2 months, so it's prety much been flushed right? Warming the engine up did nothing.
As it was leaking I put whatever fluid I had in the garage in it, could this be the problem? (Not really any... the car had the red stuff, and I added mostly the clear, does that correlate with Dextron 2 & #? The stuff I refilled it with after changing the hose is "Power steering fluid" that the parts place sold my wife. It says not recommended for Hondas, but that's it)
Any ideas, advice, similar experiences? Did I wait so long that I damaged the pump? I guess this is my fear.
Thanks
FarAway is offline   Reply With Quote
Old Jan 18th, 2005, 09:23 PM   #2 (permalink)
92redwhiteandblue
92redwhiteandblue's Avatar
Send a message via AIM to 92redwhiteandblue
I think its the fluid.....ive always put the stuff from the dealer in, but thats because i work at one, and the techs have told me that the nissan pump is made to have nissan fluid in it. It's red, but i dont know the grade, although i can get that info for you tomorow.
95 pathfinder XE
92 SE-R: grade #3 euro 10:1 pistons, shot peened crank, Centerforce Dual Friction clutch, custom enterprise short shifter, JWT/Nismo S3, Nismo Rocker Stoppers, ported & polished head, AEM CAI, AEM bypass valve, Weapon R header, custom 2.25" catless exhaust, magnaflow oval, KYB AGX, Eibach Pro-Kit, Motegi Trak Lite, Toyo T1-S, Nismo strut tower bar.....more to come!
92redwhiteandblue is offline   Reply With Quote
Old Jan 18th, 2005, 09:53 PM   #3 (permalink)
PeaNutB13
Lurkshark........
it sounds like there is still air in the system. Try doing this with the car idling. remove the PS cap make sure the resevor is filled to the proper level. turn the wheel left to right almost lock to lock, it usually takes a dozen turns to get all the air out
My Nissan kicks Ass Yo!~
PeaNutB13 is offline   Reply With Quote
Old Jan 18th, 2005, 11:29 PM   #4 (permalink)
Jed118
Jed118's Avatar
Send a message via MSN to Jed118
OK I did the SAME THING! On my sentra, it leaked heavily and when I replaced the water pump, I took "care" of the P/S hose. I put a generic one in that would pinch itself shut and then the heat would mould it differently... it was a disaster! I put in the wrong fluid, and the pump seal did not like that at all so I quickly bled all the crap outta there and put in fresh ATF. I got a hose off a NX in the wreckers (slightly shorter) and new clamps, bled the system and im doing OK! Occasionally the P/S pump will emit a short squeal, otherwise it's fine.
It's Dexron II or III ATF that goes in there! Don't put anything else in there if you want your seals to hold up!!
1993 Sentra GXE - Non stock parts (I dare not call them "mods") 2 inch NX downpipe to cat, hiflow cat, 2002 Sunfire GT right muffler, NX2000 rear disc brakes.
Coming very soon : Digital NX cluster, LED voltometer, Fog lamps. Go automatic GA16DE!! :rolleyes:
Jed118 is offline   Reply With Quote
Old Feb 21st, 2005, 11:46 AM   #5 (permalink)
FarAway
Losing fluid through the top of the PS resevoir
Thanks guys for the input. I have managed to get rid of the sqeeking, sort of. I apparently still had air. Funny thing, the first time I changed a PS pressure hose, I followed the bleeding directions carefully, this time I felt confident, and dispensed with the directions!
I'm still losing a good bit of fluid, so it squeels, and I add more. I am losing fluid through the top of the resevoir! What does this mean. I am still using a clear fluid. I was told that the red is the same stuff, with red dye so you can tell where the leak is! Is there a seal that's bad, that's letting the pressure come back into the resevoir?
Thanks
Old Feb 23rd, 2005, 04:52 PM   #6 (permalink)
Pretty White
100NX2000
Pretty White's Avatar
Send a message via AIM to Pretty White
Thanks
Now change the belt and add some Lucas Power Steering additive and it will be all good!
Team SERIOUS-NYC
91-NX2000
97-Maxima
Pretty White is offline   Reply With Quote
Old Feb 23rd, 2005, 09:48 PM   #7 (permalink)
PeaNutB13
Lurkshark........
Lucas rocks! Man that shit works.
Old Mar 3rd, 2005, 05:35 PM   #8 (permalink)
FarAway
Lucas worked great! Thanks for the tip. Didn't change the belt, because it's new, and the leaking continued long after the car stopped.
Only problem now is that steering is tight. Is this just because the fluid is so thick? Can I suck out some of the fluid and put in regular (non lucas) to thin things back out? (My weak little daughter drives this car!)
Problem with power steering?? daynado L31 2002 - 2006 3 Jan 17th, 2005 03:11 PM
New High Pressure A/C hose bad already??!!! DanaCat Truck & SUV 0 Jan 8th, 2005 12:31 AM
Help with TT Power Steering Pump kevrock529 Z32 Chassis 300ZX 7 Jun 10th, 2004 04:54 PM
power steering MyClunkyAss12er B11/B12/KN13 82-90 chassis 4 Sep 11th, 2003 09:41 PM
Manual steering to Power steering 89Sentra B11/B12/KN13 82-90 chassis 6 Aug 31st, 2002 07:55 PM
