Dimmer Switch Repair Help - Nissan Forum
post #1 of 6 Old Dec 30th, 2004, 07:21 PM Thread Starter
Hey,
My Dimmer switch on my 94 Nissan Sentra has been dying a slow death. For a while I could tap on it and it would start to work again, but I had to tap on it hard and harder and it seemed to finally break.
I tried shorting wires together at random, but all I got was a spark so I stopped. I then went to a junkyard and purchased a replacement dimmer switch but that didn't seem to work either.
So is it really my dimmer switch? Could it be something else? I checked to see if I blew a fuse when I was shorting wires, but none of the fuses seem to be blown. Is there anything else I can try? Thanks.
Vitzh is offline
post #2 of 6 Old Jan 1st, 2005, 12:47 AM
Your electrical friend
toolapcfan's Avatar
I'd say check more fuses, touching wires together at random wasn't too smart, but I'm sure you realize that. The way the dimmer works is that it resists the path to ground. The two fuses you need to check are the 10A fuse, dead center in the left column of fuses and the 10A fuse, fourth down from the top in the right column of fuses.
Rob '93 SE-R
PM or e-mail me for Progress swaybars $190 shipped, B13 Progress coilovers $1300 shipped and B13 Progress LCA brace $160 shipped.
toolapcfan is offline
post #3 of 6 Old Jan 4th, 2005, 11:02 AM Thread Starter
Thanks. I went back and looked at it and noticed I had blown a fuse. It was labeled funny, so I think I missed it the first time.
Vitzh is offline
post #4 of 6 Old Jan 4th, 2005, 01:00 PM
toolapcfan's Avatar
Yeah, the legend on the door for the fuse block is about as worthless as it gets, but at the same time, there's no way they could fit all the info on there that's needed.
Rob '93 SE-R
post #5 of 6 Old Aug 8th, 2006, 04:45 PM
a_d_y_a's Avatar
I am having the same problem. Can you tell me which fuse did you replace? What was it labeled?
94 Sentra LE, 170k+,Tan,GA16DE stock
a_d_y_a is offline
post #6 of 6 Old Aug 9th, 2006, 12:59 AM Thread Starter
To be honest its been a long time, and I dont remember exactly which fuse it was. I think it was labled something to do with the lights. At the very least if you go through them all you can easily tell which fuse is blown.
Vitzh is offline
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > B13 91-94 chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Dimmer switch :-( sentra2nr B14 95-99 chassis 20 Mar 2nd, 2008 11:44 AM
Dashboard Dimmer Switch Blows Out 40's Nissan B14 95-99 chassis 3 Jun 15th, 2004 05:16 PM
dimmer switch question se7enty7 B14 95-99 chassis 4 Mar 19th, 2003 11:45 PM
Dimmer switch not functioning Teknokid B14 95-99 chassis 25 Feb 18th, 2003 12:53 PM
dimmer switch bizz B13 91-94 chassis 3 Oct 22nd, 2002 10:43 PM
You may post new threads
You may post replies
BB code is On
