Old Nov 29th, 2004, 06:16 AM   #1 (permalink)
Hinterlander
Fuel Filler Leaks
My daughter's '93 Sentra XE 4-Door 1.6 leaks gas where the fuel fill hose enters the tank when she fills it with gas. I have read other posts about this, and it sounds like the big rubber fill hose dryrots, and the o-ring under the filler adaptor plate leaks. It's leaking gas on my garage floor.
My questions:
1) How big of a job to replace the o-ring and hose? Remove the tank?
2) Do any of the auto parts stores stock the parts?
You guys have been a big help on this car - I replaced the blower motor resistor to fix the heater from a previous post, and also replaced axle shafts from advise posted here. Thanks.
Hinterlander is offline   Reply With Quote
Old Nov 29th, 2004, 09:35 AM   #2 (permalink)
BikerFry
Come here often?
BikerFry's Avatar
Haha I just developed the exact same problem. My solution is to only fill it 3/4 full. I got under there and had a good look, and it looks like it'd be a pain in the ass to replace either the fill hose or the breather hose without dropping the tank. The tank ends of each are really tucked in there.
Is this forum still full of n00bs learning that you can't boost your daily driver on a part time retail income?
BikerFry is offline   Reply With Quote
Old Nov 29th, 2004, 01:44 PM   #3 (permalink)
Hinterlander
I can tolerate oil and ATF leaks, but fuel gets to be a problem. Advice from a previous post was to clean up the area as good as possible, then figure out what needs to be done. Looks like there is a adaptor bolted to the fuel tank that needs to come off, then the top of the filler is removed from under the fuel fill door. Then the filler pipe can be removed as a unit. New o-ring and rubber hose should do it, but I hate to do such things with gas in a garage with a gas heater.
Old Nov 30th, 2004, 02:19 PM   #4 (permalink)
sunnysentra
Nissan Addict
sunnysentra's Avatar
You will need to remove the Filler at the fender, unclap the hose and fittings and remove this piece, order a new filler neck and hose, the filler will rot also unless you have painted the thing under the wheel well like I did years ago. They corrode easy. They have had issues with maximas from 89-94 with filler neck issues, a recall was ordered because my uncle did this on my maxima back in 97. I don't know if the B13 had this issue.
Part of the AUTO / MANUAL SWAP CLUB
sunnysentra is offline   Reply With Quote
Old Dec 1st, 2004, 07:07 PM   #5 (permalink)
Hinterlander
Thanks SunnySentra, I shall give it a try.
Old Jun 8th, 2005, 10:27 PM   #6 (permalink)
MShorten
MShorten's Avatar
Did you ever replace the fuel filler pipe? How was it? I just found that the back side has a rusted "seam" and I'm looking at probably replacing it.
Regards,
Michael
Originally Posted by Matt93SE
Don't listen to him.. he doesn't know what he's talking about. ;)
MShorten is offline   Reply With Quote
Old Jun 8th, 2005, 11:02 PM   #7 (permalink)
tom434
tom434's Avatar
Send a message via AIM to tom434 Send a message via Yahoo to tom434
My questions:
same problem on my aerostar van the rubber seal was 45 bucks i had to drop the take unhook the filler tube pop the old one out pop the new in{put a little vasoline on the edge} reinsert the filler tube remount thetank 1,5 hours total.
88 pathfinder
92 sentra-e
87 aerostar
2002 rodeo 4x4
tom434 is offline   Reply With Quote
OBD II Code Chart no1see2me QG18 1.8L Engine 7 Oct 21st, 2006 12:36 PM
Show us your fuel filler flaps Exalta Cosmetic Mods 13 Oct 30th, 2004 10:34 AM
Fuel Pressure Regulator 0341TODD Z31 300ZX(T) 16 Jun 29th, 2004 08:10 AM
Installing 300zx Fuel Pump into a B14 holy200sx GA16DE 1.6L Engine 10 Jul 2nd, 2003 03:33 PM
fuel leak> evaporative canister sailer291 Truck & SUV 5 May 6th, 2003 09:58 PM
