Old Nov 24th, 2004, 03:25 PM   #1 (permalink)
dmartin
Engine power problem
I have a 1991 nissan sentra e. This weekend, all of a sudden I had no power...it sorta felt like I was running out of gas. I put gas and the car continued to feel powerless, the idle was very shaky and the muffler sounded louder. Took the thing to Pep Boys and they gave it a compression test which indicated that the 4th cylinder was dead, or not showing any compression. It's now in the hands of a very lazy mechanic (friend of a friend) who cannot tell me what it is or if it is fixable. Does anybody have any idea???
dmartin is offline   Reply With Quote
Old Nov 24th, 2004, 11:40 PM   #2 (permalink)
Pat200sx
Resident Raider Fan
Pat200sx's Avatar
Send a message via AIM to Pat200sx
Do you have a actual mechanic around (non-lazy) that could take a look at it? That might help.
GA16de
Stromung Cat-Back Exhaust, Injen Short Ram Intake, Lucino grill, Se-r rims, Toyo Proxes tires
Originally Posted by MrEous
Pancake titties...FTL
Pat200sx is offline   Reply With Quote
Old Nov 27th, 2004, 11:19 AM   #3 (permalink)
Scott
Post Freak
Moved to B13 forum.
Scott is offline   Reply With Quote
Old Nov 27th, 2004, 12:03 PM   #4 (permalink)
Slacky
Post Freak
Send a message via AIM to Slacky
were u running hot, and is there smoke coming out of the tail pipe. almost like steem, if so check your oil and anti freeze , if both are discollored then u blew a head gasket, if not then u may have jumped your timing somehow, never heard of a case of that with a ga16de yet though so im bettin on head gasket
Slacky is offline   Reply With Quote
Old Nov 28th, 2004, 12:21 AM   #5 (permalink)
Catman
Nissan Fanatic
Catman's Avatar
I had a bad/shorted plug wire recently. Ran on 3 cylinders. Last winter flooded the Sentra. All the extra gas in the cylinders gave it poor/no compression. Mechanic squirted oil in cylinders to make up for the oil the gas washed off cylinders walls. Started and ran fine after adding the oil. If you have a bad plug wire, and the injector is still pumping, maybe the cylinder with no compression is flooded with unburned gas. Or, if an injector is stuck opened, it may be flooding the bad cylinder. When the plugs were pulled, was the one on the bad cylinder wet? Or, if you look in that cylinder, is gas standing?
Truth alone triumphs, not untruth. :)
Catman is offline   Reply With Quote
93 Path - Power Window Problem tkd4au Truck & SUV 0 Oct 8th, 2004 04:32 PM
Engine cuts power Sharpie GA16DE 1.6L Engine 10 Aug 15th, 2004 11:08 AM
Power windows dead - similar problem z0098 U13 1993-1997 Altima 1 Jun 16th, 2004 08:20 PM
engine problem..help randomwalk101 Naturally Aspirated 4 Jan 13th, 2003 09:16 PM
engine problem, need help pkrSE-R SR-Series Engines (DE/VE) 10 Aug 16th, 2002 06:31 PM
